Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
  1. #31
    Dec 2012
    Fl.
    290
    Re: Been thinking to much
    If you do want to go the route of ending the coating’s life since it may be/is compromised by having done One Step before applying it, then I think your plan of using One Step again followed by regular (once or twice monthly) use of BF SiO2 Spray Sealant is a good, easy combo that won’t self-clean as well as a coating but the top layer of BF SiO2 (and use of WG SiO2 Wash on occasion as you wish) will ensure self-cleaning that is not too shabby it’s own right.
    And I know there may be overload of opinions on this thread but it is your car and your time. Read them but take them for what they are worth (and for gaining overall knowledge and options) and make the final decision
    that makes the most sense for your situation.
    Thanks so much for putting up with my confusion....there are a bunch of great guys on Autogeek....what I decided is to use is Megs. untimate polish....and then use a BF or WG SIO2 sealant once a month ....Thanks acuRAS82
  2. Thanks acuRAS82 thanked for this post
  3. #32
    Dec 2012
    Fl.
    290
    I want to thank every one for your reply's....to my confusion....what I will be doing is using just a polish and then a sealant over it. once a month....my car's paint is very clean...smooth...Thanks again
  4. Likes noorth liked this post
  5. #33
    SELF BANNED
    Jun 2019
    1,076
    Quote Originally Posted by weekend warrior View Post
    Just to add to your confusion. You can try different products/methods on different panels of your car. Lots of us do, me included.
    I personally wouldn't polish off the coating, let it ride and find a good topper/drying aid. Well maybe i would polish a door or something and try some different stuff if i was in the mood.
    Its you car, if you like working on your car often you can do all kinds of interesting tests. If i had a garage my car would have 3 or 4 different product combinations.
  6. #34
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,769
    This is the double-edged sword of AGO.
    The "good edge" is the real world experience and hands-on expertise of hundreds of hardcore detailers (both pro and hobbyist) and the all-encompassing information that they provide.
    The "bad edge" is the way that all of this info makes your head spin faster than a polisher on speed 6.
    As acuRAS82 said, after all the reading it is time to just "pick your poison" and dive in. Then, you can tweak your products/techniques as you go/learn.
  7. Likes acuRAS82 liked this post
  8. #35
    May 2017
    Pittsburgh PA
    2,847
    It is literally no problem, and I myself and I think many others here actually appreciate the questions and understand the reason for confusion. None of us would be as knowledgeable and detailing wouldn’t be as fun without having these ‘simulated’ problems to solve for others.
  9. Thanks PaulMys thanked for this post
  10. #36
    Dec 2012
    Fl.
    290
    Ok guys...yesterday was car wash day ...then I used a polish and detail spray....to me the car came out great...Been thinking to much-20200809_153238-1-jpgBeen thinking to much-20201026_131604-1-jpgBeen thinking to much-20201123_145827-jpg
    this is what I used
    WG Uber SIO2 coating wash
    Megs ultimate polish...with porta cable.
    WG profi ceramic detail spray
    Tuf shine tire clearcoat...used this about two weeks ago...tires still looked great....but I added another coat
    thanks again for your support
  11. Thanks noorth thanked for this post
    Dislikes noorth disliked this post
  12. #37
    May 2017
    Pittsburgh PA
    2,847
    this is what I used
    Just some food for thought: Coating Wash before polish is sort of a waste of the pricey wash, but it cleans and the polish will remove the protection so no biggie.
    And the PROFI Detail Spray likely isn’t going to provide you much protection. I thought you had plans to go with BF Sealant (or even a wax if you chose not to AIO with One Step).
  13. Thanks Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  14. #38
    Dec 2012
    Fl.
    290
    acuRAS82.....what car wash would you recommend....yes my plans was to use BF Sealant....but I looked thru my many coating and sealants products and I seen the coating spray...not sure if its the coating spray my car looks very dusty...I think I will use BF sealant next time....I have a lot of products that I want to give away...is there a site here I can go to
  15. #39
    May 2017
    Pittsburgh PA
    2,847
    I would have used any cheap car wash for cleaning prior to the polishing. Preferably ones that don’t leave a large amount of protection behind, which WG does. Most other car washes leave very little protection or nothing behind. The polish needs to work through the protection to get to the clear coat, so you probably just made your polishing step a bit tougher by washing with WG.
    I was just trying to point out that you don’t really have an LSP on your car. PROFI is like some light frosting on the cake, but you would be wise to put something more substantial as a base and then use PROFI QD and WG Coating Wash to maintain.
    You can post things in a thread as “Things for trade”, or if you know people who want things you could PM them directly.
  1. What are they thinking?
    By DaveT435 in forum Off-Topic
    Last Post: 09-07-2018, 06:51 PM
  2. I was thinking if its even possible...
    By marcotropolis in forum RUPES BigFoot Oribital Polishers
    Last Post: 08-08-2015, 08:57 AM
  3. Thinking about getting a DA
    By timbo7 in forum Auto Detailing 101
    Last Post: 04-15-2013, 02:11 PM
  4. Thinking of using them.
    By 997911 in forum Off-Topic
    Last Post: 03-25-2013, 09:23 PM
  5. Thinking about going to V1
    By M0nk3y in forum Off-Topic
    Last Post: 12-04-2011, 10:16 PM
» March 2024
2526272829 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
