Results 1 to 5 of 5
    Mar 2013
    North East
    166
    Applying collinite 476 at 45f??
    Its getting colder here and haven't had time to apply this . Is this too cold and will it cause me problems removing it at this temperature
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Re: Applying collinite 476 at 45f??
    It might. You're at a borderline temp, but can be done. Humidity might also play a factor for removal.
    If it were me, I'd likely just try waxing one panel at a time, rather than applying to the entire vehicle, and then trying to come behind to remove it all.
    As far as durability issues by doing such a quick wipeoff, I don't think such will be adversely effected.
    Feb 2012
    Palatine Illinois, USA
    24,529
    60 degrees is the rule of thumb with most products out thereApplying collinite 476 at 45f??Applying collinite 476 at 45f??
    2022 Elantra N Cyber Gray
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by wantboost View Post
    time to apply this. Is this too cold and
    this temperature
    •IMO:
    -(The panels’ temperature notwithstanding)...
    The main issue of removing Collinite #476 when
    the (air) temperature is hovering ~45°F, is the
    affect it may have upon the product’s “drying time”.
    -Collinite addresses this issue in the below Q&A:
    WHAT ARE THE DRYING TIMES OF OUR PRODUCTS?
    By: Collinite | May 29, 2019
    •Drying times depend not only on the air
    temperature
    but the surface temperature
    as well.
    -The ideal surface temperature is lukewarm
    to the touch, or as close to room temperature
    as possible.
    This will allow for the wax to dry at its normal
    time which is around 1 minute for a cleaner-wax;
    3-5 minutes for a liquid-gel wax; and 1-3 minutes
    for a paste wax (on average).
    Of course these times will vary based
    on wind, humidity, heat exposure and
    thickness of application.
    As soon as the wax has shown a pigment,
    or cloudiness after being applied, this means
    it is drying or “hazing”.
    •We recommend waxing at air temperatures
    between 55°F-80°F, whenever possible.
    -Waxing a hot surface or waxing in direct
    sunlight is not recommended.
    Hope this helps.
    May 2017
    Pittsburgh PA
    2,847
    I think you’ll be fine. Applying indoor (garage)?
    I’ve applied numerous sealants and LSPs in the 40s (including 915), and as long as their isn’t windchill causing areas to partially freeze, it seemed to work fine. Maybe some reduction in performance but possibly nothing noticeable. I like Mark’s idea of applying to smaller areas and then wipe off.
  1. Replies: 8
    Last Post: 06-29-2017, 02:43 PM
  2. Applying and removing collinite 915
    By godfearingman in forum Auto Detailing 101
    Last Post: 02-13-2015, 11:54 AM
  3. Replies: 38
    Last Post: 05-06-2013, 07:13 PM
  4. Applying Carnuba Wax on top of Collinite 845
    Last Post: 03-14-2013, 08:09 AM
  5. Before applying EX-P and Collinite 845
    By DrMike in forum Auto Detailing 101
    Last Post: 11-13-2006, 05:50 AM
