Re: Sonax Brilliant Shine Detailer blotchy application?
Many great tips with how to use BSD. The most important for me is to use it sparingly. 1-2 sprays per panel is enough. If you are to use it as a QD you can dilute it up to 1:5. Then you are able to spray on more solution that way. And honestly I would skip the wax after the next polishing and just apply BSD on dry paint. If you do this I usually spray in a mf towel. Spread it out and then a dry buffing mf towel to soak up the what's left. No dwell time is needed just wipe on and wipe off.
If you like to spray directly on the paint. Yeah we all like different ways. Then it's a bottle called Flairosol bottle that has a very fine mist that spreads it out evenly. If it's windy don't use this as it will land every where you don't want it to land LOL. Also I personally like to dilute it 1:1. But then it's sprayed on almost fully covered. It's a testing game to get the right amount that suit your method with BSD.
Here you have a so called Flairosol fine mist spray bottle.
EZ Mist Sprayer - Black
I finally got around to buying a better sprayer today! I've been using it straight since last year, but not using it much.
So I'll try it out mixing it 1:1 with some distilled water, or maybe mixing it with some Meguiars Ultimate Quick Wax? I know lots mix it with CG V07, but its $28/btl (473mL) up here vs. $17 for the UQW (709mL). Why is everything so expensive up here now?!
By tonosity in forum Auto Detailing 101
Last Post: 04-30-2018, 06:43 PM
Last Post: 02-07-2018, 06:32 PM
By Soifon in forum Product Reviews
Last Post: 12-15-2016, 03:52 PM
By Loach in forum Product Reviews
Last Post: 07-28-2015, 11:44 PM
By 1vh1 in forum Auto Detailing 101
Last Post: 02-21-2014, 05:47 PM
