Re: Does fixing a dent damage paint in anyway?
Quote:
Originally Posted by
LSNAutoDetailing
It shouldn't crack. But if your wife says it will, then she is always right. I've had PDR work done on my vehicles, and when I was in business I had PDR guy. i've seen it done dozens of time, never saw any cracking. So unless your ding is on bondo I would be concerned.
And if you're smart, you won't push this any further......... ;)
The hardest part of this whole thing is it's on a body line... that is what I'd be more concerned about.
LSNAutoDetailing
Definitely. That design line will probably be lost as the dent is worked out ... at the very least it will not be as well-defined.
Ugh ok, we値l I知 an idiot. Well regardless I知 try to get it repaired.
I値l post if when I do, thanks
TrustJesus
My truck is getting done today. I can post before and after if you like.
Sent from my VOG-L04 using Tapatalk
Yes I would like to see before and after pics.
TrustJesus
Ok. Before polishing:
https://uploads.tapatalk-cdn.com/202...b13533d552.jpg
After paint transfer and scratch removal:
https://uploads.tapatalk-cdn.com/202...53e0f949d3.jpg
https://uploads.tapatalk-cdn.com/202...19b3f63e90.jpg
After PDR:
https://uploads.tapatalk-cdn.com/202...91ba3cfc92.jpg
https://uploads.tapatalk-cdn.com/202...85ec91669c.jpg
I'm really happy with the results. Well worth the $125 he charged.
I’m glad it worked out for you, I am. We all deserve a break every once in a while.
If my SUV doesn’t stay the same, Ill be happy with it being less noticeable.
Dent is gone, technician had to drill a small hole because the metal was hard.
So if you ever get a dent, don稚 be discouraged.
