Re: Carpro Immolube
Originally Posted by ct18
read some reviews and one of the positive was it smelled good. Maybe yours is old. They also said to dilute 15:1, did you dilute.
Immolube is ready to use, not meant to be diluted.
EDIT: Never mind, I was mistaken and the product is not RTU.
Re: Carpro Immolube
CarPro recommends to dilute it.
Dilutions:
Claying 1:10 ~ 1:20.
Wet Sanding: 1:15 ~ 1:20
Primary Applications:
Synthetic clay.
Reduces unwanted marring.
Wet sanding.
Directions:
Dilute to suit purpose and tool.
Shake well.
Spray over the sanding disc, or clay bar and over the work area.
Begin sanding or claying, keep surface lubricated.
Wipe off once complete or wash as needed.
Re: Carpro Immolube
Dilutions:
Synthetic clay.
Wet sanding.
Directions:
Shake well.
OK, my mistake then. I had read about it but I actually never used the product because I thought it wasn't meant to be diluted and thought the cost was too high. I use Glide with Nano Skin and find that it works pretty well, much better than ONR as clay lube.
Re: Carpro Immolube
Immolube is good. Does get sudsy with a clay mitt or clay towel and loads up the wipe off towel. No suds with a clay bar. Only thing I don't like about it is that it needs a prep wipe to remove the residue. But it's pretty cheap considering the 1:10 dilution.
Re: Carpro Immolube
I dilute it. It says on the bottle to do so, if I’m not mistaken. It didn’t even come with a sprayer.
I’ll have to check my bottle when I get home, but it says it on carpros website.
Re: Carpro Immolube
I didn’t have the issue of a prep wipe, but I just used it after I finished washing the vehicles I’ve used it on. Sprayed it out of a pump sprayer on to a wet car and went to town, then rinsed the residue off.
It does say on my bottle to rinse it off, I’m not sure if it’s always said that though. It’s definitely not the most convenient thing to use if you don’t want to do that though, I’ll admit.
Re: Carpro Immolube
I also always clay as I finish washing and then rinse the whole car again, never liked leaving some clay lube behind (potentially).
Re: Carpro Immolube
You clay after every wash?
Re: Carpro Immolube
A panel wipe is a must as CarPro states to remove the residue. You rinse it so that explains why you don't experience it. Plus the residue it leaves behind is not polymers or anything so it won't harm anything in the correction process if a bit is left behind.
I have no desire to rinse again once I have the car in the garage. Does not seem as efficient but that is just me.
Re: Carpro Immolube
No, but when I clay, I do so right after the wash and chemical decontamination, then do a final rinse. Some people finish the wash and then clay with the car already in the garage and just before polishing. I do all the prep the night before and then it can be completely dry in the morning for taping/polishing.
By JWilliams.RadiantDetail in forum Product Reviews
Last Post: 12-30-2019, 04:21 PM
By Donalds detailing in forum Auto Detailing 101
Last Post: 10-26-2017, 08:45 PM
By SYMAWD in forum Auto Detailing 101
Last Post: 06-14-2016, 11:04 PM
By StephenK in forum Auto Detailing 101
Last Post: 03-11-2016, 10:02 PM
By BostonDetails in forum Customer Comments
Last Post: 05-13-2012, 10:45 AM
25 | 26 | 27 | 28 | 29 |
