Results 1 to 9 of 9
    SELF BANNED
    Jun 2019
    1,076
    2 step correction - 3D One x2 or 3D One + Gyeon Primer?
    What do you guys think of a 2 step correction on a 2018 Nissan Rouge?
    1st step - Test spot with 3D One with a 50/50 eurofiber, 2 slow passes. Take it from there.
    2nd step - Finish off with 3D One or gyeon primer with a soft polishing pad or black pad.
    Super Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    Re: 2 step correction - 3D One x2 or 3D One + Gyeon Primer?
    Hey noorth,
    Here's what I would suggest because this is what I would do. Don't do two set passes and go. Do one pass at a time, wipe off after each with panel wipe and check results after each pass.
    I would say do the trunk with this combo. Then try 3D One with a polishing pad on one side with the same process of one pass at a time, then do the same with gyeon primer with a soft polishing pad in the same process and then see which one you like better, which one gets you the best results, etc.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  3. Thanks noorth thanked for this post
  4. #3
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    What's the paint damage look like?
    What color?
    Nissan paint is pretty soft & black Nissan paint is even softer.
    Ripping through your mind like a hurricane full of novocaine
  5. #4
    SELF BANNED
    Jun 2019
    1,076
    Quote Originally Posted by WillSports3 View Post
    Hey noorth,
    Makes sense. Very practical.
    Thanks.
  6. #5
    SELF BANNED
    Jun 2019
    1,076
    Its white.
    The car has never been polished.
    I'm a newbie so i don't know the level of damage. I will be inspecting it when i get home to my skill level lol
  7. #6
    Jun 2016
    Toronto, ON
    1,453
    TO be honest, I find myself sometimes overworking a product at times when for example, two or three passes would've cut already but I ended up doing 5 to 6 because I started introducing more marring than needed with loaded up clearcoat. So now, I test spot one pass at a time. Kevin Brown test spot method.
  8. Likes noorth liked this post
  9. #7
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    I’d do a test spot with 3D One with a polishing pad before any of those other two combos. It might be all you need to do.
    Those euro fiber pads are ok but they will leave haze on soft paint.
  10. #8
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by noorth View Post
    What polisher are you using? Post a pic of the paint too. You might be able to get away with a 1 step with Just Primer. Nissan has just a tick above "soft" paint. Using a forced oscillation/rotation unit like a Flex or so will yield stellar correction with just a polish. Yes, I use primer as a 1 step with a light cutting pad such as an orange LC Pad or Yellow Rupes pad with great results. Skip a black pad, it has no cut. Use a yellow, green, white, (colors irrelevant really) depending on the system used. Use a light cutting or polishing pad with Primer. I have lots of examples in the Show-n-Shine area.
    This Firebird Firehawk got a full correction with Primer only and the paint here was Medium to hard
    This BMW M5 Got a 90-95% correction with Primer and an Orange Pad
    2023
  11. #9
    SELF BANNED
    Jun 2019
    1,076
    Quote Originally Posted by TTQ B4U View Post
    Looks like i opened up pandora's box.
    Yeah that's what i'll do, i'll get some pictures in a few days.
    Thanks!
  12. Likes TTQ B4U liked this post
  1. Gyeon Q2 Primer
    By noorth in forum GYEON Car Care Products
    Last Post: 04-17-2022, 02:32 PM
  2. Replies: 40
    Last Post: 09-26-2020, 04:57 AM
  3. Replies: 35
    Last Post: 04-28-2020, 09:03 AM
  4. Gyeon Primer vs Polish
    By Koogs in forum GYEON Car Care Products
    Last Post: 09-04-2018, 10:21 AM
  5. Gyeon primer vs carpros essence
    Last Post: 05-03-2017, 08:01 AM
