Results 1 to 8 of 8
    Super Member TrustJesus's Avatar
    Apr 2020
    San Antonio Tx
    535
    Right way of using wetsand to remove certain scratches?
    Hello AG, good day.
    I want to grasp the concept why some scratches will only improve using wetsand?
    Can someone educate me on when to start wet sand to improve a scratch in general?
    My goal in life is to love God, family and myself. To love others and treat others right.
    Aug 2020
    914
    Re: Right way of using wetsand to remove certain scratches?
    Some scratches are too deep for a mild compound tio effectively grind smooth. Sandpaper may knock the edge down. In some cases, it may be better to leave a deep scratch than try to level it completely. You sand through the clear you are SOL.
    Apr 2020
    San Antonio Tx
    535
    @DUBLOW
    Would having a paint thickness gauge help to keep clear coat in check?
    Aug 2020
    914
    Based on what I've read before, if you can feel a scratch with your fingernail, it's probably too deep to safely remove. I really can't comment as to how effective a paint thickness reader would be in this type of situation.
    Apr 2020
    San Antonio Tx
    535
    Got it, thanks for your time.
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    My suggestion: If you aren’t experienced at sanding, don’t do it ....especially on factory clear coat. You are better off living with some scratches that sanding thru clear coat.
    Jim
  7. Likes DUBL0WS6 liked this post
  8. #7
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    Quote Originally Posted by TrustJesus View Post
    Hello AG, good day.
    What you are doing is leveling the rough edges surrounding the scratch. If the scratch is only penetrating the clear coat, then wet sanding will level the scratch and compounding/polishing will remove the sanding marks.
    If you can feel the scratch with your finger nail then you need to use touch up paint to fill the void. Filling a scratch is an art in itself. Takes multiple coats over several days. You don't want to apply too much base coat as you need to build up with clear coat. Exception, is if your using a base coat, clear coat mix.
  9. #8
    Apr 2020
    San Antonio Tx
    535
    Sounds good, I got it now.
  1. Remove deep wetsand marks with DA on hard paint
    By Jershinator in forum Ask your detailing questions!
    Last Post: 04-20-2019, 12:28 AM
  2. Removing wetsand scratches what am I doing wrong
    By maesitos in forum Wet-Sanding, Cutting & Buffing
    Last Post: 09-21-2015, 08:41 AM
  3. How to wetsand to remove orange peel
    By MitchLiving in forum Wet-Sanding, Cutting & Buffing
    Last Post: 08-11-2015, 08:06 PM
  4. How to remove scratches in glass - Wiper Scratches from Beach Sand
    Last Post: 04-11-2014, 05:02 PM
  5. TSR to remove 2k grit wetsand marks?
    By res313 in forum Wolfgang Car Care
    Last Post: 07-18-2011, 06:52 AM
