Re: Hand sanitizer on tree sap... now what?
Last weekend I used Sonax BSD as an experiment for a 'detailer' on my sons car after parking under a honey locust tree.
It cut through the little bumps effortlessly. I was somewhat surprised with the results.
The car is my test bed for a minute before we polish it.
I go with Mike’s suggestions. Never use something on your vehicle that wasn’t designed for your vehicle.
Secondly never aggressively go at something if you don’t know the outcome.
Yesterday there was a series of stringy gummy things of tar or some foreign substance on my coated mustang. It may have been tar, it may have been chewing gum for all I know.
I grabbed an MF and lightly saturated a spot on the towel about the size of my finger tip with tarminator. A product I’ve used dozens and dozens of times on all different cars. I gingerly spread it on the foreign substance, applying no pressure, and the substance loosened.
I then went over it with another MF, loads of ONR, then another MF and QD. I had to do this in about 4 locations. No issues, no scratches, coating and clear intact.
Don’t go by wives tales, use tried and true products. You may need to just lightly polish that spot with an AIO as Mike suggests.
Originally Posted by
AutowerxDetailing
Denatured alcohol works significantly better than isopropyl alcohol to remove almost any kind of tree sap.
Interesting. I'll have to try that.
Is that because of chemical composition or because of alcohol concentration levels?
Denatured alcohol and isopropyl alcohol are the same thing aside from additives added to the alcohol to make it toxic to drink. Please don’t drink Isopropyl alcohol either but the base for denatured alcohol could be fit for “drinking” before it’s denatured. Bottom line is for cleaning purposes alcohol is alcohol depending on concentration/purity.
I agree with you 100 percent Paul. Never use the most aggressive method. For example in Interiors, I 99 percent of the time don't use APC. My favourite cleaner of choice is McKee 37 Rinseless wash in an IK foamer at a 1:65 dilution ratio and a soft brush. Let dwell for a minute or two then agitate.
LSNAutoDetailing
2016 Mazda 3 Sports GT
2015 Lexus IS250 F Sport
