Results 11 to 20 of 34
    Aug 2017
    51
    Re: Gyeon can coat prep
    Hi guys,
    what do you think about using 3D One with a black finishing pad to polish before coating?
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by heloguy View Post
    Hi guys,
    Really depends on your test spot and if you are content with the finish.
  3. Thanks heloguy thanked for this post
    Likes Paul A. liked this post
  4. #13
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Hi guys,
    Personally I see no point. Black pads have no real cut and unless you're paint is aftermarket and orange peel free, it won't have any significant refinement applied that would be worth anything. I would simply pop on a light polishing pad and give it a once over. I would also recommend you look the coating line you plan on using to see if they have a primer or base-coat polish you can use. CarPro Essence or GYEON's Primer are two that come to mind for their respective coatings. Being this is a CanCoat thread, I'd stress using Primer. It's a great product and helps CanCoat go on and off easier. It's my go-to polish for GYEON coatings.
    2023
  5. Thanks heloguy, Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  6. #14
    May 2017
    Pittsburgh PA
    2,847
    Hi guys,
    And after your test spot, fully buff the area, spray some prep spray, wipe off and see if you feel any slickness at all or is the surface squeaky clean?
  7. Likes heloguy, Paul A. liked this post
  8. #15
    Aug 2013
    St Louis metro (Illinois)
    5,796
    Quote Originally Posted by TTQ B4U View Post
    Agree and I'd go so far as to say using a black pad would be a waste of time. It's REALLY soft and better suited to applying an LSP. If you wanted to go very gentle a blue LC pad would be a better choice. Realistically, I'd think a white pad with 3D One would be a good starting point for a test spot.
  9. Likes acuRAS82, heloguy, Paul A. liked this post
  10. #16
    Aug 2017
    51
    I ordered a bottle of 3D AAT 502 polish. I’m going to use that with a black pad. (That’s what they recommend) if it’s not working well, I’ll switch to a blue pad.
    That should get me prepped for Can Coat.
  11. #17
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    If that is the recommended pad, then I would not doubt their instructions to start with.
    But like you stated, you can always switch it up.
  12. #18
    Jun 2013
    LA, CA
    8,719
    They recommend it as it's a follow up to their AAT compound where the compound may leave haze and require finishing. I agree with the others on just using a polishing pad. You are not going to remove that much clear if that is what you are worried about.
  13. #19
    Aug 2013
    5,796
    I'm surprised they recommend a black pad at all. Even to remove compound haze I'd use a white or blue pad depending on the paint. The black is so soft I see it having only one real use.
  14. #20
    Jun 2013
    LA, CA
    8,719
    I haven't tried the AAT compound but if it is anything similar to ACA 500 then I can see why as it finishes good on most paints. Especially on harder paints.
  1. gyeon wet coat
    By wkndwarrior89 in forum Auto Detailing 101
    Last Post: 10-18-2021, 12:14 PM
  2. Review: GYEON Q2M Leather Cleaner and GYEON Q2 Leather Coat by Mike Phillips
    Last Post: 02-19-2019, 08:13 AM
  3. Very surprised by the lack of filler removal by gyeon prep
    Last Post: 01-06-2019, 11:33 AM
  4. Gyeon Wet Coat
    By glfnaz in forum Auto Detailing 101
    Last Post: 12-22-2016, 07:38 PM
  5. New paint prep and Gyeon Mohs curing outdoors
    By Wolfslair in forum Auto Detailing 101
    Last Post: 09-05-2016, 04:53 PM
