Re: Questions about machine polishing
Originally Posted by Epilogts
So I ordered:
Polish
Reflect
Scholl S40 (Carpro said it wouldn’t work as well with a DA...)
Pads
Scholl’s Honey spider pads
Rupes Yellow(recommended by CarPro)
LC hydro red, in addition to the LC orange and white I already had.
Hopefully this will be a good mix for finishing out my hard paint...
Scholl Concepts NEO Honey Spider Pad is a fine, porous pad designed for use with S20 Black on soft paintwork, for high gloss hologram-free finishing and for efficient application of NEO Polymer Protection by machine.
Hmmm, better for soft paint
More Scholl’s honey info...
The cut level of these pads falls between a Lake Country Hydro-Tech Crimson, and a Scholl Concepts Orange pad (Which is itself a little milder than an LC HT Tangerine pad.). They do provide a useful amount of cut to help remove marring from more aggressive compounding steps, unlike the soft open-cell foams many associate with ‘finishing pads’. Due to their design, however, they are capable of maxing-out the finishing potential of polishes to a much greater extent.
For S40
You can use pressures ranging from absolute zero, to maximum with a free-rotation 8mm DA when using Scholl, and need to depending on the stage of the set and that required by the defects at hand. So too, can the travel speed change within a spectrum.
When spreading the polish for the initial pass, I would suggest using the weight of the machine alone. After this is accomplished, you can bump-up speed, and apply as much pressure as is needed. If you want to adjust the aggression of your pad/polish combo downwards, you can continue using the weight of the machine. If you want to truly maximize it, though, apply as much pressure as the machine can handle while still maintaining 1-2 RPM's per second of the backing plate. One can also use anything in between; how much pressure to use exactly requires some practice. If you're using less pressure than maximum, you might also want to increase your passes by 1-2 over what I listed, as the reduced friction will cause the product to break down just a little slower.
For the final pass at speed one, I'd recommend machine weight, or one machine weight pass, followed by one at absolute zero... Whereby one lifts the machine to take its weight off of the pad, and lets it free-spin, while still keeping it level with the paint. This takes practice, but can help in finishing down on very sensitive paints/plastics.
As for travel speed, again, this depends. Generally, the approximately 1-inch per second arm speed rule of thumb applies very nicely on 8mm free-throw DA's, in regards to Scholl. However, on more heat sensitive surfaces this can be increased to 2+ inches per second, and on harder paints, you can shrink your polishing area from the standard 18X18 inch zone with a 5.5" pad, to 12X12, prime the pad more heavily, and polish at even less than 1-inch per second for greater correction.
There are always lots of ways to adjust your technique to change your results to fit the application... Furthermore, all of the Scholl polishes themselves are a little different. All of them hold onto their primary abrasive size for different levels of time before diminishing. All of them have a different 'sweet spot' when it's best to stop polishing. Depending on the tool/pad you're using, the nature of the paint, and your pressure/speed, the number of passes you take and your arm travel speeds change. This sounds complicated to try to figure out in the field, but it really isn't...
Scholl polishes/compounds will tell you what to do, and when you need to do it. You can feel the transition point when the abrasives have started to break apart, and moments later are fully broken down... You feel the point when the polish loses friction, and goes smooth under the pad. This is more obvious with the more aggressive products (It's easier to feel with S17+ rather than S40.), but even on the mildest ones can be detected... You won't see it, because the lube will look the same. You'll feel it... It's not a feeling that will smack you in the face (It's more noticeable with some pads/machines than others... It's real easy to feel on rotaries, with the compounds. Less so on a forced rotation DA, with the finishing polishes.), so you have to let your mind/hands relax to sense it, and stay focused, but it's always there... Once you feel that transition, lighten up, and just ride out that finishing cycle... How long you ride the finishing cycle depends on various factors. There's a 'sweet spot' of when to stop. Figuring out that 'sweet spot' is more about practice than any feedback you'll get. You get a feel for the timing... How long is 'too long', when the swarf starts to do more harm, than running the finishing leg out can keep doing good.
Another note... My technique with Scholl was developed mainly on very soft, very sticky paint, that was very unforgiving. These paints require exacting timing and pressure control... Medium or harder paints are much more forgiving, and you won't see the differences in finish quality by running the polishes a pass or two too long or too short, that you will on soft finishes. If your paints aren't that problematic, realize you have some wiggle room... Play by the numbers if you can't play by feel... You're not going to get spanked for it like you will on the soft stuff. On 'normal' spectrum paints, you can just get the basic concept of how these products break down, and relax to a certain degree. It's when you're in an extreme situation that you have to maximize every ounce of what these polishes can achieve, that you need to get REALLY HARDCORE about having your timing/pressure transitions being perfect. Otherwise, you've got some margin of error to play with.
Ok, hit the lady’s grey GTI with the HF polisher and Scholl’s S40 and Reflect on a Scholl’s honey pad.
I wanted it to add some good gloss, not sure if it is the hard paint or what, but neither seemed to do much... I did about 4 passes, and although it looks good it doesn’t have any crazy reflectivity. Perhaps my expectations are to high for factory clear coat?
Four passes really isn't all that much. I typically do 6~8. A lot of it depends on the product and how it works. Also, grey like other lighter colors, is really hard to get amazing reflectivity like you'd see from darker colors.
One of the most maddening things for me was working on my old metallic grey Mazda3. I could get it shiny, but no where near the reflectivity of black or other dark colors.
4 passes for a small throw D/A is not much. 4 passes with a long throw D/A does a lot. I normally do 4 - 5 passes with a long throw.
2016 Mazda 3 Sports GT
2015 Lexus IS250 F Sport
Thanks guys, I work it a little longer and see if things change.
Hit it again...
8-10 passes, slow arm speed on a honey pad, with S40 on a test spot (12”x12”).
Still no big change. Paint doesn’t show any marring or swirls with a good LED flashlight, but I still feel like it lacks depth.
Oh well, that’s as good as I can get it...
Is your car Quatum Gray? I saw a car in this color over the weekend and thought at the time how hard it would be to detail.
Hit it again...
I would like to see this in person. Could try to help you dial-in a process that works.
Where you located?
By bigterp in forum Auto Detailing 101
Last Post: 09-30-2019, 10:45 AM
By nyjetfan in forum Ask your detailing questions!
Last Post: 04-08-2015, 02:37 PM
Last Post: 06-05-2014, 01:07 AM
By nodule in forum Auto Detailing 101
Last Post: 10-15-2013, 08:41 AM
By HFDFyreFytr in forum Show N' Shine
Last Post: 09-20-2011, 09:42 PM
