» Detailing Classes
Results 11 to 20 of 28
    Senior Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,026
    Re: Sooo....what's wrong with my clear coat?
    Quote Originally Posted by TNMIKE46 View Post
    And by the way, Awesome car. Looks like a SS-396. Am I right?
    There was no such thing as a 1967 SS396 Camaro that I'm aware of.
    Oct 2012
    Sheboygan Wisconsin
    3,026
    Your car is a prime candidate for a Ceramic Coating. That will "toughen up the paint" that such a soft paint won't keep getting hammered, even when just taking off a car cover. The question is, "what coating"?
    I've used a couple so called coatings, and bought right here, and I didn't think they were any better than a regular sealant, or even a WOWA sealant.
    In fact, I thought they were worse. And yeah, one of them was Pinnacle Black Label, cost me an arm and a leg. I'll never buy PBL again. Left me very un-impressed
    Go with CQuartz UK, problem solved!
    Oh, and if you haven't done such in some time, wash the cover! A dirty cover does cause sleeks and marring.
    So, with that said, are you up to the task to again finish polish, prep and coat?
    Have a D/A, Pads, the right chemicals? If not, you perhaps should have, and learn to use them.
  3. #13
    Oct 2012
    Sheboygan Wisconsin
    3,026
    Or, you could go the simple route.... Buy a bottle of good glaze. Poor Boys is outstanding (Black Hole). Apply, and finish-top with a good sealant or wax.
    Wolfgang 3.0 is good, Collinite is good, I'll take and use either versus PBL!
    Colly #845 is very good, #915, or especially #476 is tougher yet.
    One question I hadn't asked, how old is the paint? Did they-you perhaps toy with it before full cure-dry time?
    Some paint jobs, there's no baking, lights, zero, simply done in somebody's garage is all.
  4. #14
    Senior Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,170
    Quote Originally Posted by HAMBO View Post
    Thanks, sounds like you feel the same pain!
    I had been using exclusively waterless (and the occasional rinseless) washes after reading Mike's article about best practices in taking care of older cars. Have you had any issues using lots of water on an older car?
    Thanks!
    All seals are in great shape. Also no pressure washer. Just a garden hose. I will also blow dry so no water sits anywhere. So I haVe had zero issues.
    Jim
  5. Likes HAMBO liked this post
  6. #15
    Oct 2012
    Sheboygan Wisconsin
    3,026
    Thanks!
    Using water period on these vintage classics is a mortal sin!
    Two Bucket washes, grit guards, foam guns and all that other whacky BS is fine for a newer Korean Hyundai S&ht Box. You do NOT want water going down inside door panels, or anywhere else where it will sit for eons and cause rusting.
    Carpro H2O is a very good all purpose waterless wash-detailer. There's many more. Step up your game, this isn't an everyday car.
    As I said in an earlier reply, a tough coating might save you tons of grief. But can you apply it, or pay some fly by night hack $700 to do it?
    There's an old saying "Too many Chefs spoil the Cake"
  7. #16
    Member HAMBO's Avatar
    Jan 2017
    Los Angeles, CA
    99
    Thanks! Indeed it is, though original motor is long gone.
    Quote Originally Posted by MarkD51 View Post
    Indeed there is, but the 396 was introduced midway through production of the 67s.
  8. #17
    Jan 2017
    Los Angeles, CA
    99
    Thanks for the perspectives.
    Yes, I have CarPro ECH2O, hasn't solved the problem. Per original post car is already ceramic coated, which I had hoped would help, but didn't really do the trick as hoped.
  9. #18
    Senior Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,058
    This seems to be just left over liquid. Try using distilled water and double check the dilution ratios. I'd also suggest doing a final wipe after you WW/RW your car. The streaks of left over lubrication should be just fine if you spritz the towel with a little bit of distilled water.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  10. #19
    Oct 2012
    Sheboygan Wisconsin
    3,026
    Sorry for my mis-information, I should know better since I did once own a '68SS396.
    Yours then is quite a rare vehicle. Is there still a big block under the hood may I ask?
    I'm hoping what you are experiencing is not so much soft paint, but as others have touched upon, possible residues left behind? Your comments though seem to say otherwise.
    I know you have mentioned you car had been coated, but I think all who have used various coatings will agree, all are not created equal.
    I was not trying to offend either PBMG, or users of certain coatings when I spoke of Pinnacle Black Diamond, or others I've also tried. There's products who have their fans and detractors.
    I'll admit many of these spray and wipe coatings hold advantage of ease of use, and how I've also read about more than a few having problems with some coatings like CQuartz. Various application issues with high spots left behind, water spotting, on and on.
    But I would say without any revocation, that coatings like CQuartz are some of the most durable consumer available coatings to be had. That a product such as CQ UK does leave behind a very hard top protective layer to any and all paints.
    When I first used CQ UK, I was very pleased of the hardness and durability of the coating.
    Also sorry about mis-naming CP ECH20. I do have this product on hand and like it.
  11. #20
    Member TNMIKE46's Avatar
    Jun 2018
    35
    So HAMBO, is it a true SS396?? Just curious due to the somewhat rarity of one. Sorry if I'm "beating a dead horse" here LOL.
  1. Megs #7 Show Car Glaze on Black Base Coat/Clear Coat...
    Last Post: 09-21-2018, 08:55 PM
  2. clear coat repair gone horribly wrong......
    By Bones106 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 07-18-2017, 08:19 PM
  3. Replies: 2
    Last Post: 06-11-2016, 03:42 PM
  4. Is this clear coat/ sign of clear coat failure?
    By Aririguzo in forum Auto Detailing 101
    Last Post: 11-11-2014, 07:11 AM
  5. what am I doing wrong/clear coat & wax Q's
    By shaolinfox30 in forum Auto Detailing 101
    Last Post: 03-14-2014, 01:56 PM
Members who have read this thread: 94
» May 2020
2627282930 1 2
3 4 5 6 7 8 9
10 11 12 13 14 15 16
17 18 19 20 21 22 23
24 25 26 27 28 29 30
31 123456
