Results 1 to 9 of 9
    Regular Member HAMBO's Avatar
    Jan 2017
    Los Angeles, CA
    126
    Using a drill to polish tight spots
    Hello AG,
    I'd like to polish a few tight / small spots on my car that will be a bit hard to get to with my normal DA polisher. I have seen some attachments for using a handheld cordless drill as a polisher, and I was wondering whether that might do the trick without spending money on a whole new smaller polisher.
    Anyone have any luck doing that and have any tips or recommended drill adapters? Also I'm very much a novice with a polisher so have always been comforted by the random wobbles of my DA so as to avoid damaging the paint. Would using a drill to polish be more dangerous given it wouldn't have that benefit?
    Thanks!
    HAMBO
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    Re: Using a drill to polish tight spots
    If your drill has variable settings you should be ok.
  3. Thanks HAMBO thanked for this post
  4. #3
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Just use a little common sense, and you should be ok.
    But remember, the drill has zero random orbital ability, and the farther away the small(ish) pad is from the drill (like with an extension) the more unstable it can become.
  5. #4
    Dec 2018
    7,164
    If you have a dremel their are a ton of attachments for that
  6. #5
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Meguiars has a DA kit for a drill. They recommend using a corded drill, but I have had success using it on a Dewalt 20v cordless.
    The attachment uses 3" pads (or 3.5?) And is random orbit.
    Cost wise, I think they are under 40$
  7. #6
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by JustJesus View Post
    I actually bought one of these for spot duty. 4" pads are not great for reaching into tight areas, but the unit is solid and does a better job on a small, flat area that can be done by hand IMO.
  8. Thanks HAMBO thanked for this post
  9. #7
    Jan 2017
    Los Angeles, CA
    126
    Thanks! I will check it out.
  10. Likes JustJesus liked this post
  11. #8
    Oct 2014
    1,294
    Agreed. Not the best for tight areas. That's when I use the GG3, or go by hand. No nano type polishes yet. Oh, duh. Or PE8 with 1" pad of I can fit it.
  12. #9
    Oct 2014
    1,294
    Quote Originally Posted by HAMBO View Post
    I have video on YT if you search for DA Power System. On scratched up 4Runner.
    Lousy video, but you will get an idea how to use it, how big it is, etc.
  13. Thanks HAMBO thanked for this post
  1. How much CFM recommended to blow dry tight spots and possibly the whole car?
    By TheMidnightNarwhal in forum Auto Detailing 101
    Last Post: 04-16-2018, 10:55 AM
  2. drill for polish: why not?
    By sansa in forum Auto Detailing 101
    Last Post: 03-19-2014, 08:14 AM
  3. looking for advice - to drill or not to drill
    By timaishu in forum Off-Topic
    Last Post: 03-25-2012, 09:09 PM
  4. Prism Polish + Water Spots
    By PT87 in forum Ask your detailing questions!
    Last Post: 07-20-2011, 11:01 AM
  5. Polishing tight spots
    By Moedizzle in forum Auto Detailing 101
    Last Post: 02-19-2009, 08:16 PM
