Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Re: Weird discoloring on factory Tonneau, could this be from my Carpro products? Any fix?
    Quote Originally Posted by zachmat View Post
    Well I went out this evening like a weirdo and did a real quick spot wash, little agitation and it came out.
    Sounds like whatever it was - it was water soluble.
    Sometimes things that are water soluble are not cleaner or solvent soluble. It's easy to think it wouldn't matter but it does. And sometimes the simplest approach is the best approach.
    When people ask for help with sticky plastic or sticky feeling steering wheels and they've tried some type of APC cleaner, I recommend going SIMPLE. Try some normal liquid hand soap and some water in a wash cloth and wipe the sticky surface down. Sometimes it works.
    This is why you often see me doing waterless washes with SONAX Glass Cleaner. It's water based with cleaning ability and it doesn't leave anything behind. Works great to remove dirt off a car as well as some oily substances.
  2. Thanks zachmat thanked for this post
    Likes zachmat liked this post
  3. #22
    Jan 2020
    We'll I spoke too soon, it appears to turn black again when wet, once it dries the discoloring is back. Back to square one. Still perplexed what the hell it is and want to keep the coating in tact and not go harsher for fear of harming the plastic. In the end its just a tonneau but my OCD its bothering me lol.
  4. #23
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Wipe it down with some Eraser, possibly APC followed by Eraser. Finish with a coat of DLUX.
  5. #24
    Mar 2018
    Conroe, Texas
    477
    But if the color persist you might want to try Solution Finish to get that 'Black' back. Then if happy then I would use the DLUX if the top was coated previously.
  6. #25
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by Thomkirby View Post
    The thing is that since it already has DLUX on it, solution finish is not going to penetrate all the way through as the coating has sealed in most of the pores. Been down this road with SF and topping it with a coating and it in the long run it does not work that well when it comes to reapply once again as SF doesn't absorb like it originally does.
  7. #26
    Super Member Icarus's Avatar
    Oct 2019
    Ontario, Canada eh!
    269
    How long has the coating been on it? I'd guess its not there anymore at all...
    ·Ï¢årµ§·
  1. New hard plastic tonneau cover. Products?
    By 72Malibu in forum Auto Detailing 101
    Last Post: 05-31-2020, 01:19 PM
  2. Replies: 0
    Last Post: 12-28-2018, 02:56 PM
  3. I had a dream (weird detailing products discussion)
    By joshs2000ss in forum Off-Topic
    Last Post: 01-17-2017, 09:50 AM
  4. Menzerna Products...factory direct or AGO?
    By 93ls1rx7 in forum Auto Detailing 101
    Last Post: 11-27-2013, 12:37 PM
  5. LC Pads Discoloring!?!?
    By galaxy in forum Wool & Foam Buffing Pads
    Last Post: 04-19-2011, 09:42 PM
