Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jan 2020
    Pointless to pre-spray with ONR if I am doing a regular soap wash?
    Hey, is it pointless to pre-soak with ONR if I am doing a regular soap and water wash?
    May 2017
    Pittsburgh PA
    2,847
    Re: Pointless to pre-spray with ONR if I am doing a regular soap wash?
    Quote Originally Posted by wyclef View Post
    Not pointless at all. It’ll help soften the crud and add slight lubricity. I think of it as better safe than sorry and totally worth it if you have the pre-spray resources available. Worst case, you used $0.20 and 5 extra minutes of time that wasn’t needed. Best case, you cleaned better and reduced some swirling.
  3. Likes Jim w, PaulMys, mc2hill liked this post
  4. #3
    May 2010
    ankeny ia
    1,301
    totally a good idea
  5. #4
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    ^^^ Couldn't have said it better myself ^^^
  6. #5
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    ...totally worth it if you have the pre-spray resources available.
    Agreed. And when it comes to "pre-spray resources" you can get by with something as simple as a pump-up hand sprayer like one of these :
    Wolfgang Chemical Resistant Pressure Sprayer, pressurized spray bottle, pump sprayer
    I found something similar locally, and a bit cheaper.
    48oz. of solution (I use Uber at waterless ratio) is more than enough to pre-treat our mid-size SUV.
  7. #6
    Dec 2018
    7,157
    I agree with pre spraying car with something. If no foam cannon then yes get a garden sprayer and go to town with a rinseless/waterless pre soak.
    I just got the IK 12 and use it to foam presoak when not using PW. I use a snow foam and its awesome. If not wanting to foam a handheld pump sprayer will be fine.
    As Acura said, It can’t hurt and anything that provides lubricity will probably help.
  8. #7
    Jan 2020
    Thanks! I have the IK 1.5 foamer that I use for wheels, haven’t been all that happy with it so I got the Marolex 2l pump sprayer I will use for the ONR which I really like doesn’t lose pressure as fast as the IK 1.5 foamer. Maybe the larger ones are better. Supposed to be in the high 40s over the weekend and sunny so probably will try out a few things. Anyone know if ONR wash and wax will work under 50 degrees? I was using Opticlean in 24 degree weather and it was clouding up on the panels a bit.
  9. #8
    Dec 2018
    7,157
    Most sprayers will be fine to cover your car in one to two pump ups. Foamers need alot more air/pressure so all of them require alot more pumping.
    Never used ONR. Most my rinseless’sxwork sub 50 degrees but they usually dont leave anything (wax/polymers) behind. That is usually component that will streak.
  10. #9
    May 2017
    Pittsburgh PA
    2,847
    I have plenty of gloss WWs and RWs. As long as the surface is a few degrees above 32, they shouldn’t cloud. If the weather is barely above 32 and there is wind or no sun, you might have clouding. Anywhere above 35-36 shouldn’t cause issues.
    Plus, you are only pre-treating with ONR and then washing. Shouldn’t have any issues above 32. NOTE: At 24 degF, even if using warm water to mix, I would expect any WW to start frosting/clouding within seconds after thinning on the surface.
  11. #10
    Super Member Rmd's Avatar
    Dec 2012
    Orange County, CA
    713
    Does the pre-rinse with ONR happen after you spray car with hose to remove loose dust? Or, are you pre-soaking first, then rinsing followed by soap wash?
    When I foam prior to bucket wash I’m foaming dirty car, then rinse, then soap wash. For rinseless wash, I pre-soak, then go right to using bucket of towels (Gary Dean) method. Never fully trusted the Big red sponge, but that’s a totally separate discussion.
    Curious how you integrate rinseless solution into soap bucket wash process.
  1. Quick Wash/Detail Between Regular Detailing
    By 5js in forum Auto Detailing 101
    Last Post: 09-30-2019, 01:33 PM
  2. Should I thoroughly clean a customer's rims in a $20 regular wash?
    By JICs Auto Detail in forum Auto Detailing 101
    Last Post: 05-11-2018, 08:43 AM
  3. Starting a business rinseless wash vs regular wash
    By RecurveTrail214 in forum How to make money detailing cars
    Last Post: 05-02-2016, 11:38 PM
  4. Regular Car Wash Vs Auto Detail
    By tcfatboys in forum Auto Detailing 101
    Last Post: 02-20-2012, 01:26 PM
  5. Replies: 12
    Last Post: 08-30-2011, 06:38 PM
