Results 1 to 4 of 4
    Newbie Member Lawndawg's Avatar
    Jun 2011
    Iuka, MS
    Wolfgang Trim Sealant Running?
    I知 having issue with WTS running down the side of my truck after a rain. Could it be because I知 leaving to much product on the trim? The area around my mirrors is the worst. Not really doing it from the window trim.
    Wesley
    "You'll have that"
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Re: Wolfgang Trim Sealant Running?
    Yes, it could be that you're applying it a bit too heavy. After application you might need to come behind with something like a paper towel to smooth, and remove excess.
    The other is perhaps not enough time to dry-air out. Certain weather conditions such as cold or high humidity will likely slow drying and curing.
  3. Thanks PEAD19 thanked for this post
  4. #3
    Jun 2011
    Iuka, MS
    Thanks. I figured that was the prob.
    Wesley
    "You'll have that"
  5. #4
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    I use McKee's37 Trim Restorer, which many believe to be the same as WETS, and what I have found is that "smooth" plastic trim needs to be given a light wipe after application to remove excess and "level" things out. Whereas "textured" plastic trim seems to be more porous and absorbs product more readily. I use a dense foam applicator as cheaper, more porous foam seems to lend to over-application, and when needed, do the light wipe with a MF towel.
  6. Likes PEAD19 liked this post
  1. Replies: 7
    Last Post: 01-07-2017, 08:42 PM
  2. Replies: 8
    Last Post: 08-21-2014, 06:41 AM
  3. Replies: 5
    Last Post: 06-18-2013, 01:35 PM
  4. Replies: 49
    Last Post: 08-29-2011, 10:17 PM
  5. Replies: 14
    Last Post: 07-13-2011, 06:38 AM
