» Detailing Classes
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Feb 2015
    Ft. Lauderdale,Fl
    589
    Re: Sticker glue help
    Quote Originally Posted by SwirlesY View Post
    I've tried that mate, no joy :/
    It has to sit on the goo for a bit and usually takes several application/wipe offs to break down really old goo. A plastic razor blade also helps the process without marring your paint. Goo gone or 3M adhesive remover or the 3M citrus cleaner might work. I have all of them at my disposal but rarely had to use anything but WD-40.
  2. #22
    Jan 2020
    Quote Originally Posted by Whitewater25 View Post
    I've tried that mate aswell as a few others. I'm not sure if it is very clear on the video I've out on but there is a slight mark on the right that looks like some paint has come away. The mark isn't like the normal adhesive that's left over, it's absolutely solid.
    It's a bloody nightmare this is mate.
  3. #23
    Member Sleper's Avatar
    Mar 2006
    55
    Heat gun or hair dryer, plastic razor blade and alcohol. Patience is the key to removing the adhesive.
    It won't take much to burn through the clear so take your time. Heat, scrape, wipe with alcohol and check your progress often.
    3M adhesive remover may help in softening the glob.
    For the 3m adhesive or wd 40 I find if you soak a towel hold against the affected area for 15 minutes to disolve works best. Good luck
  4. Thanks SwirlesY thanked for this post
  5. #24
    Jan 2020
    Quote Originally Posted by Sleper View Post
    Gave this a go yesterday to no joy. I've put the badges back on for now until I have some spare funds to get it sorted.
    Thanks for everyone's advice and time
  6. #25
    Feb 2015
    Ft. Lauderdale,Fl
    589
    You might have to polish afterwards but there is a 3M pinstripe removal tool sold here that worked to get the worst of my badge residue off after I got what I could off with WD-40. I replaced the badges so it was not a big deal if the paint wasn’t perfect, but I polished the paint anyway.
  7. #26
    Mar 2017
    Missouri
    340
    Rapid remover is pretty good stuff. Heat works well to soften it up and scrape it off with something plastic like a plastic razor blade .. or maybe even an old gift card or something.
    https://kaliberdetailing.com
    Kaliber Auto Detailing
    Every Detail Matters
  8. #27
    Jan 2020
    I will give the 3M and/or the rapid remover a go but unfortunately it will have to wait until a later date as she is due a major service and some other bits and bobs.
    Thank you again to everyone who took the time to help and offer any advice.
    When I eventually get round to having another go I will post the results
  1. Stickers glue
    By kerenzv in forum Auto Detailing 101
    Last Post: 07-07-2013, 08:09 AM
  2. need glue...
    By snellvilleauto in forum Auto Detailing 101
    Last Post: 05-16-2012, 06:50 AM
  3. Glue on Leather
    By ilb3 in forum Auto Detailing 101
    Last Post: 10-24-2010, 09:30 PM
  4. Glue On Paint
    By MuranoGuy in forum Off-Topic
    Last Post: 03-08-2009, 04:20 PM
  5. Removing Sticker Glue
    By DAS in forum Auto Detailing 101
    Last Post: 07-20-2008, 07:01 AM
Members who have read this thread: 71
» February 2020
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
