Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Regular Member chinee's Avatar
    Aug 2018
    West Palm Beach, FL
    110
    Getting into the nooks and crannies around emblems...
    I would usually just use a detailing brush with the car soap every other wash or so to clean the emblems, up, down, circular, over and over, to really get into the nooks and crannies. Then after a close examination during drying, I went to town with the corner of MF towel, but there’s still crud in there. I’m thinking a Q-tip is next with some wax, soap, detailing spray, or something... but thought I’d ask you guys first. What do you do to really get into these tights spots?
    At first glance, these don't look too bad, but zooming in, the crud is evident.
    May 2008
    199
    Re: Getting into the nooks and crannies around emblems...
    De-badge vehicle as much as possible, then you don't have to worry about it. These newer cars all have stickers on the badge backing, not like they used to be with holes drilled through the panel and nuts holding them on from behind.
  3. Likes brianc636 liked this post
  4. #3
    Sep 2019
    55
    Quote Originally Posted by sqeekykleen View Post
    Yes and no. I’m a HUGE fan of de-badging a vehicle as soon as it get it however my son’s Honda and wife’s Acura both have trunk emblems that are held on by 2 sided tape and posts through the panel.
  5. #4
    Aug 2018
    West Palm Beach, FL
    110
    Debadging was a thought but I was thinking of pursuing a cleaning method before going in that direction.
  6. #5
    May 2011
    1,205
    Steam
  7. Likes Eldorado2k liked this post
  8. #6
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Simplest way is just keep at it with the softest detailing brush you can lay your hands on, and something like a waterless wash spray.
    Carpro Ech2O comes to mind.
    Try to let the liquid products do the work as much as possible by pre-soaking.
    Advice after that is be as careful as possible when applying products near any and all badges and trim.
    Possibly consider converting after to WOWA Sealant products like Optimum Opti-Seal, or Ultima paint Guard Plus which leave basically zero residues behind. Or going further up the ladder, a good Ceramic Coating, and then maintain with the dedicated spray maintainer products.
  9. #7
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by Billy Baldone View Post
    Steam
    This.Getting into the nooks and crannies around emblems...
    I had some of the hardest freakin wax stuck in the cracks of my trim...
    I tried the products.
    Tried letting it dwell and brushing a Bunch of times...
    Wouldn’t budge. The previous owner must’ve have used Nu Finish or something!
    Finally used the steamer and viola... Gone!
  10. #8
    Aug 2018
    West Palm Beach, FL
    110
    Steam cleaner sounds like the ticket, but I don’t have one. Thinking now about rubbing alcohol in some hot water, 1:1, with a small detail brush.
    Maybe some APC in hot water as well.
    Any other ideas?
  11. #9
    Nov 2015
    13,765
    Quote Originally Posted by chinee View Post
    Any other ideas?
    Cut the bristles of the brush down a bit with some scissors so they can provide stiffer agitation.
  12. #10
    Jan 2017
    Byron Canter MI
    96
    I have found this detail brush helpful. No guarantee it will take care of your problem but both the bristles and the soft but firm rubber edge take care of a lot of problems.
    Mothers Detail Brush Set cleans crevices and creases inside your car. Mother Detail Brush Set includes 2 small brushes.
  1. APC for cleaning emblems
    By Ruben12 in forum Auto Detailing 101
    Last Post: 02-23-2018, 12:02 AM
  2. Question for Rinseless Gurus- Media for grills/nooks/crannies
    By oneheadlite in forum Auto Detailing 101
    Last Post: 06-14-2016, 12:37 PM
  3. Nooks & Crannies: How do you handle them?
    By dooyaunastan in forum Auto Detailing 101
    Last Post: 03-28-2014, 06:51 PM
  4. Car emblems
    By oldgeek in forum Auto Detailing 101
    Last Post: 08-23-2012, 03:14 PM
  5. nooks and crannys
    By dublifecrisis in forum Auto Detailing 101
    Last Post: 02-17-2009, 12:52 PM
