Results 11 to 20 of 29
    Jul 2019
    Chicago
    38
    Re: Coating Maintenance
    I do wring my mitts onto the ground after rinsing before soap water dunk.
    I didnt use reset last time, and I did use reset today, It seemed to make a difference, I've only used reload on one panel to test.
    Sent from my SM-N950U using Autogeekonline mobile app
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Supposedly, Carpro Reset is one of the few that doesn't have shine enhancers added Most OTC shampoos do.
  3. #13
    Dec 2018
    7,170
    Coating Maintenance
    It’s Definitely not the reset. Id guess road grime and film building up. From what ive read most products to remove this seems to be alkaline usually.
    That is kinda why i like toppers is so that when grime builds up, its buildimg on the topper. Im hoping alkaline products are only harming topper when i use these washes and then re top.
    Those are my thoughts but not sure if that’s how it works.
  4. Likes Reuben Brumby liked this post
  5. #14
    Super Member vobro's Avatar
    Jun 2012
    Homer Glen Il
    1,156
    Op just try these simple steps for a month, keep clean with Reset or ECHO2 and leave it alone. If the coating was applied correctly you don't need to go nuts protecting the coating, let it do its job as intended
  6. Thanks Reuben Brumby thanked for this post
    Likes The Guz, Reuben Brumby liked this post
  7. #15
    Nov 2016
    253
    I'd be furious if I took the time and $$ to install a 2-part coating and had to "top" it after the 3rd wash, winter not withstanding.
  8. #16
    Jul 2019
    Chicago
    38
    So I just gave the car a thorough wash with reset yesterday, and it looked much better this time. Still not as slick but more of the glassy appearance returned.
    Part of my problems may be due to the curing process.
    It was cold and very dry when I installed the coatings. There was a lot of salt dust on the roads here.
    The car was so dirty and my wife had so many potential detailing clients eyeballing my work at her job that I jumped the gun and washed the car with reset 3 or 4 days after installing.
  9. #17
    Jun 2012
    Homer Glen Il
    1,156
    Well that may explain the loss of slickness on the GLISS, per CarPro detergents are to be avoided for 5-7 days
  10. Likes The Guz liked this post
  11. #18
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Wash it with Wolfgang Coating Wash and you will be fine. Pricy but really good product. It will restore any hydrophobic and slickness losses.
    Wolfgang ber SiO2 Coating Wash
    Jim
  12. #19
    Aug 2013
    St Louis metro (Illinois)
    5,809
    Quote Originally Posted by vobro View Post
    Great advice from my experience with coatings.
    In the winter I'll notice the lower door areas and the rear of vehicles will loose some of their water sheeting ability due to the salt and grime. However, once spring arrives and I can wash the cars by hand on a regular basis (I use Optimum Car Wash), all the coating properties quickly return after only a couple of washes. I've seen the same results with a couple different coatings and haven't felt the need to do anything more serious.
  13. Likes Reuben Brumby liked this post
  14. #20
    Nov 2018
    77
    Quote Originally Posted by MarkD51 View Post
    Naw, I'd say you didn't cause any damage, Carpro CQ UK is pretty tough stuff.
    There's a number of ways you could go. I used to be a big fan of Carpro Reload way back, before the number of various re-formulations created a product I no longer trust to use personally. Yeah, it still works, but, there's others out there.
    Others that might be easier to work with, but perhaps will still only provide short term results.
    Such as Blackfire Coating Booster, or Blackfire SIO2 Spray. There's a multitude of such products now available. Both here and abroad.
    I think whatever you top CQ UK with, you won't hurt it. You'll know when CQ UK is gone
    IMO, you'll get basically similar results from all. Unless you're willing to decon, prep, and do another coat of Gliss? Or their "Lite" product? Never used such, or Gliss.
    is it necessary to top any ceramic coating with a topper like reload? what happens if you never do? i think why need to top might as well not put the ceramic coat on to begin with will you not just be getting the topper?
  1. Coating Maintenance Routine
    By spewking in forum Auto Detailing 101
    Last Post: 05-20-2019, 08:42 AM
  2. SIO2 Coating Maintenance
    By bfenne in forum Auto Detailing 101
    Last Post: 06-29-2018, 01:21 PM
  3. Maintenance Post Coating
    By LSNAutoDetailing in forum Auto Detailing 101
    Last Post: 07-10-2016, 07:40 PM
