Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Super Member MrOneEyedBoh's Avatar
    Mar 2013
    1,186
    Question on Uber RW/WW dilution ratios
    So looking at Wolfgang's website I see there are multiple ways to dilute it for whatever reason needed, cool.
    This is what I'm confused on.
    When I do a RW, I use 3 gallons which is at 1oz uber to 3gal of water.
    But the detail spray says to use 3oz to 1 gal of water.
    That's a lot more concentration of Uber in that than the RW.
    Should I be upping the amount when I do RWs? Hopefully I didn't scratch the paint to hell by using 1oz to 3 gal of water ...
    Thoughts?
    Super Member C5Longhorn's Avatar
    Jun 2015
    379
    Re: Question on Uber RW/WW dilution ratios
    I think you are fine with the 1 oz. to 3 gallons of water. The detail and clay lube will intentional be a heavier concentration.
    I follow their recommendations and haven't noticed any issues.
    Sent from my Pixel 3 XL using Tapatalk
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by MrOneEyedBoh View Post
    When I do a RE,
    I dilute 3 gallons at 1oz to 3gal of water.
    I do RWs?
    Thoughts?
    Really no reason to up the recommend
    amounts for any of Wolfgang Über Rinseless
    Wash’s intended purposes, IMO.
    There’s often some dilution ratio confusion
    with these type of products that, IMO, is
    caused by not defining the difference(s), if
    there are any, between Waterless-Wash
    solutions, and Detail Spray solutions.
    Regardless:
    I’ll use a Detail Spray solution in a similar
    manner as I would a Waterless Wash solution
    (and vice-versa): “really wet”.
    •According to Wolfgang:
    1.) When you add 3 ounces of Über Rinseless
    Wash to a gallon (128 oz.) of water...you’ll wind
    up with a net 131 oz. of a Detail Spray solution.
    2a.) It takes 1/3 oz. of Über Rinseless Wash mixed
    with 15 2/3 oz of Water...in order to get 16 oz. of
    a Waterless Wash solution.
    2b.) With that being the case, it would take 3oz
    of Über Rinseless Wash mixed with 141 oz. of
    Water—for a net 144 oz of WW solution:
    •That’s pretty daggone close to the dilution ratio
    of the above mentioned Detail Spray solution;
    -and, also meets my premise regarding the
    likelihood of using WW solutions and Detail Spray
    solutions interchangeably...wouldn’t you say?
  4. Likes MrOneEyedBoh, Thomkirby liked this post
  5. #4
    Mar 2013
    1,186
    So what should I use dilution wise for pre-soaking the panels? I was using the 1/3oz to 16oz dilution...
  6. #5
    Mar 2017
    Southeastern PA
    2,480
    It works fine at that dilution ratio. It's normal for a quick detailer to have more product in it than a rinseless wash.
    Bruno Soares
  7. Likes MrOneEyedBoh liked this post
  8. #6
    Mar 2017
    Southeastern PA
    2,480
    I used 1oz in a 1.5L sprayer for the pre-soak solution.
    Bruno Soares
  9. Likes MrOneEyedBoh liked this post
  10. #7
    Mar 2013
    1,186
    Quote Originally Posted by BSoares View Post
    What's the reasoning? I would think the wash would be more concentrated to eliminate scratches etc.
    Crazy to think that little is good enough when the detail spray is waayyyy more concentrated
  11. #8
    Mar 2017
    Southeastern PA
    2,480
    I think because they know for a quick detailer people will spray much less solution and wipe it, potentially with a dry towel. In a rinseless situation you have more solution on a very wet towel so that's enough lubrication with the recommended dilution ratio.
    Bruno Soares
  12. Likes Coatingsarecrack liked this post
  13. #9
    Super Member JWilliams.RadiantDetail's Avatar
    May 2013
    710
    I use it and never noticed that, reading the label I find it odd the QD ratio's much stronger than the Waterless dilution.
  14. #10
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Follow the directions and you will be fine. As I mentioned to you in my PM response, dunk your spray bottle into the rinseless wash solution you make to use as your pre spray. No need to over think it.
  15. Likes MrOneEyedBoh, PaulMys, cyclops liked this post
  1. Replies: 12
    Last Post: 09-13-2020, 04:16 PM
  2. Dilution ratios - ??
    By Don M in forum Auto Detailing 101
    Last Post: 06-23-2016, 07:43 PM
  3. APC+ Dilution Ratios
    By kochdalton87 in forum Auto Detailing 101
    Last Post: 08-06-2013, 10:35 PM
  4. CG Dilution Ratios
    By Calendyr in forum Products Guides
    Last Post: 08-01-2013, 08:58 PM
  5. OPC Dilution Ratios
    By ARizzle in forum Auto Detailing 101
    Last Post: 11-06-2012, 08:50 PM
