Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Meg's PlastX
    Jun 2014
    Chandler, AZ
    3,360
    Meg's PlastX
    Is PlastX good on chrome plated plastic trim?
  2. Thanks Thomkirby thanked for this post
  3. #2
    Super Member davey g-force's Avatar
    Aug 2009
    1,225
    Re: Meg's PlastX
    Can you test it on an inconspicuous spot?
    Depending on what you've got & what you're trying to achieve, I think it would help, and certainly shouldn't hurt anything.
    Quote Originally Posted by Jason Rose
  4. #3
    Jun 2014
    Chandler, AZ
    3,360
    Re: Meg's PlastX
    Quote Originally Posted by davey g-force View Post
    Great idea... I was thinking along the same lines. My daily driver is loaded with plastic coated chrome (it's usually my test subject for most things). Think I might give that a shot this morning, answer my own question and the update this thread.
  5. #4
    Nov 2015
    Los Angeles, California
    13,752
    Re: Meg's PlastX
    It works GREAT on chrome plated plastic trim. Great on chrome wheels too.
  6. Likes davey g-force liked this post
  7. #5
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Meg's PlastX
    If the plastic is truly chrome plated (which some are and some aren't) then the care of should be the same as any chrome plated part regardless of the substrate.
  8. #6
    Nov 2015
    13,752
    Re: Meg's PlastX
    Quote Originally Posted by 2black1s View Post
    Try taking some steel wool to plastic chrome... I’ve yet to see that happen without scratches occurring.
    But Plastx works wonders on plastic chrome trim. Removes nearly all visible defects & blemishes i.e. staining/water spots/etching. [not scratches]
  9. #7
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Re: Meg's PlastX
    of the substrate.
    What’s a fool-proof way of determining if
    a plastic component is truly chrome plated...
    versus it being faux chrome plated?
    {I sure wouldn’t want to be the person
    that, unwittingly, screws something up.}
    TIA.
  10. #8
    Nov 2015
    13,752
    Meg's PlastX
    Speaking of Steel Wool & Plastx.. I decided to try a little experiment earlier today to see how each fared on 1 of my chrome wheels which had recently taken the abuse of having brake fluid constantly leak over it for a couple of weeks until I had it fixed. I went through four 12oz. bottles of brake fluid, to give you an idea of how much fluid leaked on this wheel.
    1st up Steel Wool.
    Close up view.
    Polished most of it away within seconds.
    Next up Megs Plastx.
    Before.
    Before.
    After. Results were equally as easy.
  11. Thanks Diner thanked for this post
    Likes acuRAS82, davey g-force liked this post
  12. #9
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    Re: Meg's PlastX
    TIA.
    If a plastic part is electro-plated with chrome, it must first be "seeded" in order to be electrically conductive. A metal (such as pieces of silver) is planted within the plastic part. Then, once it is conductive, it is plated first with a layer of copper and then plated with chrome.
    The other method of "chrome plating" plastic parts is via vacuum metalization... the part is placed in a vacuum chamber where aluminum, which has been evaporated electrically, is deposited on the part surface via vapor deposition. After that the part is clear-coated for protection.
    So, there really isn't any way to tell, short of a scratch test, which would be self-defeating. Since none of the metals used in the process will attract a magnet, that trick will not work.
  13. Likes davey g-force liked this post
  14. #10
    Aug 2009
    1,225
    Re: Meg's PlastX
    Quote Originally Posted by 57Rambler View Post
    Wow, interesting!
    So I guess that's why some plastic chrome doesn't scratch easily (i.e. behaves like real chrome) and some is scratch sensitive?
  1. PlastX question
    By AZpolisher15 in forum Auto Detailing 101
    Last Post: 12-11-2015, 09:07 PM
  2. PlastX Review
    By Isaiahjones12 in forum Products Guides
    Last Post: 10-16-2013, 07:26 AM
  3. Meguiars PlastX
    By Buggy Bath in forum Tricks, Tips and Techniques
    Last Post: 06-10-2012, 09:44 PM
  4. megs plastx
    By PA DETAILER in forum Product Reviews
    Last Post: 04-23-2011, 05:57 PM
  5. PlastX Question
    By Nuke33 in forum Auto Detailing 101
    Last Post: 01-02-2007, 10:04 PM
