Results 11 to 20 of 22
    Jul 2013
    Apex, NC
    1,283
    Re: To 3k sand or not
    You would end up with a smoother paint surface using the #3000 or #5000 first knocking down the orange peel texture a bit. Does the current condition of your paint really warrant wetsanding?
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Quote Originally Posted by Every_detail View Post
    I get this, but Im wondering are there any major differences from sanding 3k versus long passes with a MF pad and say, m100.
    After sanding with 3k you still need to polish and a lot of time this will require a 2 step polish.
    Any time you can compound and polish to get the job done would be better than wet sanding.
    Maybe the 5000k-8000k that Mike mentioned will be easier.
  3. #13
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    •Since none of my OEM vehicles have ever
    been predetermined/destined to be entered
    into any Custom Car Shows...
    -I need my vehicles to retain as much of
    the protective CC paint film layer as I can
    Humanly {and possibly humanely} provide.
    Consequently...
    •When it comes to OEM factory paint systems:
    -I don’t wet/dry sand them
    -I don’t use anything more aggressive
    than something along the line of Meguiar’s
    Ultimate Compound
    •With the above in mind, I’m compelled to ask:
    -What’s the advantage to do otherwise?
  4. Likes Rsurfer, tomsteve liked this post
  5. #14
    Jan 2007
    14,094
    Quote Originally Posted by DBAILEY View Post
    It appears that the OP is talking about trashed paint. Wouldn't consider using a rotary with a wool pad and compound to smooth out orange peel. Maybe a denim pad and a da would work..dunno never used a denim pad.
  6. #15
    Jan 2011
    908
    Don't wetsand anything unless you have experience or at least some type of basic training. You can run into problems very quickly. Practice on a junk panel first before doing a customer car.
  7. Likes tomsteve liked this post
  8. #16
    Regular Member Every_detail's Avatar
    Apr 2014
    Westbrook, ME
    147
    correct. paint that's trashed to where it would be faster to sand and polish out.
    Quote Originally Posted by Kaban View Post
    I have plenty of experience wetsanding and knowing when and when not to.
    this is just a general question
    This is more of a topic Im just asking about. I see a lot of detailers online and IG that go right to 3k handsanding on trashed paint because it allows them to keep their heat under control and not letting the paint swell.
  9. #17
    Keeping temperatures low is better for the paint and one advantage to dampsanding over a heavy compound process.
    I forgot I wrote this article but seems to fit here,
    Destructive Polishing - Don't get clearcoats hot! by Mike Phillips
  10. #18
    Jan 2007
    14,094
    "I have plenty of experience wetsanding and knowing when and when not to."
    To the OP if what your saying above is true, why are you posting this thread?
    Is it because you have no experience with a rotary and a wool pad?
  11. Thanks Kaban thanked for this post
    Likes FUNX650, Kaban liked this post
  12. #19
    Apr 2014
    Westbrook, ME
    147
    This was more towards the ones I see that go right to wetsand and compound to reduce heat into an extremely beat panel. Does it do more damage or not, basically. Guess I should've stated it totally different.
  13. #20
    Jan 2007
    14,094
    IMO if the paint is that trashed and a aggressive method needs to be used..put a paint gauge on it before anything else.
    3000k versus rotary with a wool pad and compound would be a close race in removing clear coat.
    BTW trying to remove RIDS with 3000k imo is wasting your time. If the panel is really trashed and has enough clear then start with 1000k and work up to 3000k.
  14. Likes FUNX650, Every_detail, tomsteve liked this post
  1. Can I use my DA to sand?
    By TheMidnightNarwhal in forum Auto Detailing 101
    Last Post: 04-08-2018, 12:57 AM
  2. Will this wet sand out?
    By vettefever17 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-18-2016, 04:20 AM
  3. How much can i wet sand ?
    By Gcleov in forum Wet-Sanding, Cutting & Buffing
    Last Post: 02-14-2016, 10:34 AM
  4. How often can you wet sand?
    By queens guy in forum Auto Detailing 101
    Last Post: 07-30-2013, 02:01 PM
  5. OLD Sap... Wet Sand??
    By courtdale in forum Auto Detailing 101
    Last Post: 09-19-2011, 10:35 AM
