Re: Carpro Cquartz
Originally Posted by
Rsurfer
You put a wheel coating on your windshield? Or did you mean your wiper cowl?
On the windshield! It looked just like the glass coating while going on and seems to be doing good.
Wonder if there is much difference between glass coating and wheel coating?
Re: Carpro Cquartz
Desertnate
While I hate having to keep those plastic bits from getting scratched up, I actually like them better than the unpainted plastic or matte black paint. From my experience the paint is always really thin and single stage which fades and oxidizes quickly. The plastic doesn't age as well either and since every OEM uses a slightly different type of plastic, finding a trim protectant which will work on that particular car is a lottery.
You are absolutely correct about it being a lottery. Used Dlux on several B pillars with excellent results. Tried it on a Infiniti and it streaked like crazy. Had to polish it off and applied CQuartz with no problems.
Re: Carpro Cquartz
58LesPaul
Your guess is as good as mine, but I'm glad it worked out for you.
Re: Carpro Cquartz
The Guz
It depends on how much paint is on the vehicle. It takes about 10-20 mls applying two coats. More if one is a first time user.
What about first time users cause them to use more coating? Just curious so I can correct myself next time.
Re: Carpro Cquartz
58LesPaul
Is more better or less is best?
Re: Carpro Cquartz
58LesPaul
One word experience.
Re: Carpro Cquartz
The Guz
Can you elaborate on that? Putting too much coating on the pad each time?
Re: Carpro Cquartz
58LesPaul
Exactly. My advice is to keep practicing with a coating. You will get to a point of how much to use and work with. It’s really not that hard to use one. The individual focuses too much on what can go wrong and that throws everyone off.
A high spot is not the end of the world. It is called a lessons learned.
Re: Carpro Cquartz
The Guz
Exactly, Mike.
Just like anything you do, practice it.
The Gloss Coat "someone" sent me was a breeze to use. I went into it thinking a bit too much, and then 2 minutes into it (much like using a polisher the first time), you are like "WTH was I worried about???"
Re: Carpro Cquartz
PaulMys
Exactly, Mike.
It was the same for a polisher for me. I decided on a boss 15 over the gg6 but was scared poopless. After the first two panels getting used to it it was like what was a scared of? And since then using a gg6.... although a great tool.... the gg15 was not much harder to use but definitely faster, smoother and just nicer in every way.... glad I did. No need to upgrade later.... the gg9 looks like a closer step to the boss’s tho.
