Results 21 to 30 of 35
  1. #21
    Sep 2016
    46
    Re: applying ceramic for the first time,
    well i just went ahead and ordered these:
    http://grabilla.com/09b05-8a6f0e12-a...da1a3893ca.png
    dont think i need anything else do i ??
    apparently the Lite cquartz is arriving soon so i might just apply that, but i must say the original cquartz doesnt seem impossible to do either ! and i may end up Trying it on the family car !...
    Quote Originally Posted by BSoares View Post
    The secret is to use and then immediately soak them in a bucket with APC/MF cleaner and then once done wash them all. No need to throw them out.
    just wondering since i have just 4 towels if soak the WHOLE towel in water immediately after applying the coating on a single panel. then i guess not many towels left to do the whole car right ??! or i need more towels in this scenario ? does that apply for cquartz Lite as well ??
    finally can i dilute 2oz of MF cleaner with a whole bucket of water or any special dilution ratio etc..?
  2. #22
    Mar 2017
    Southeastern PA
    2,480
    Yeah, 4 towels probably only enough to do one layer of whatever coating it is. Lite will require same amount of towels.
    2oz sound fine, you really just need them to stay wet and any cleaner will just help break down the curing that could be starting.
    Bruno Soares
  3. #23
    Sep 2016
    46
    I found this extremely informative
    YouTube
  4. Likes BudgetPlan1 liked this post
  5. #24
    Sep 2016
    46
    My question actually is if I throw that entire towel immediately into a water bucket right after removing the flashing product from ONE SECTION. Well then I will probably need maybe 15 towels or so not just 4 ?!...
  6. #25
    Mar 2017
    Southeastern PA
    2,480
    Quote Originally Posted by jojokoko View Post
    Use two towels at a time. After about half car you switch them with clean ones. Soak the ones you were using. So 4 towels per layer of coating. You can use more but I’d say 4 is the minimum for each layer.
    Bruno Soares
  7. #26
    Dec 2018
    7,157
    You’ll need to have at least 4 and I say 6 to remove coating. Remember you’ll Need to follow up with a towel for buffing and leveling after you remove.
    Like I and budget mentioned before get a 10 pack of TRC 300-350 edgeless and you’ll be fine.
    You won’t replace the buffing/leveling towel as often.
  8. #27
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Here is what I have done and it seems to work. I fill up a bucket with a couple gallons of water. I then add a strong mixture of Micro Restore into the bucket. Once I feel that the towel is not absorbing product but rather pushing it around I will toss it in the bucket and let it soak. I will do the same for the other towels after I am all finished. I will then wash them in the washing machine with more micro restore but less concentrated. The towels have come out fine so far.
  9. Likes jojokoko liked this post
  10. #28
    Sep 2016
    46
    You want to do Trix before claying and polishing. So you can do that before they get your car. Just make sure to wash it after applying and before taking your car in for polishing.
    dammit it seems like i will have to find another detailer then ! my car is already coated ! they need to Remove the old coat, by polishing, clay and decontaminate, then polish again after claying, use IPA, and its all up to me then to install the new coat.
  11. #29
    Sep 2016
    46
    ok thanks that probably what am gonna do then !...
  12. #30
    Dec 2018
    7,157
    They can polish once after the other steps even if your removing a coating. Claying, Iron remover, Trix (tar remover). All are gonna remove bonded contamination which will be on top of your old coating. Once removed polish and bingo.
    Still say if your gonna spend $300 buy a g8 and do it yourself. Not hard at all just gotta be a little careful.
  13. Thanks jojokoko thanked for this post
  1. applying Ceramic coat over Zaino CS
    By Ilyam3 in forum Product Reviews
    Last Post: 09-14-2019, 01:35 AM
  2. Do I need a special polish before applying a ceramic coating?
    By MSTucker in forum Auto Detailing 101
    Last Post: 06-17-2019, 09:23 AM
  3. Suggestions for applying Ceramic in Honeycomb grille
    By mrmarkmac in forum Auto Detailing 101
    Last Post: 03-23-2019, 08:25 AM
  4. Applying sealant to ceramic coating
    By garfy in forum Ask your detailing questions!
    Last Post: 02-23-2019, 06:22 PM
  5. 2017 F-150: Am I applying Ceramic Coating Properly?
    By LethalLimited in forum Auto Detailing 101
    Last Post: 04-09-2018, 03:04 PM
