» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Clearcoat issue
    Oct 2019
    Re: Clearcoat issue
    It must of been covered up then by more clear as it wasn’t like that till I started cutting into it to level things off. I’m assuming to fix would be complete repaint of Dior etc?
    Oct 2019
    Re: Clearcoat issue
    I should of just left it way I had it. But no have to keep trying to get it perfect. Mind you the cars almost 15 years old and has its share of little things here and there. I already repainted a fender that clear had totally started coming off and paint was flaking
  3. #13
    Jul 2016
    3,328
    Re: Clearcoat issue
    Quote Originally Posted by Gaspar74 View Post
    I know that just that area there was spray painted to fix a chip and an where it had started rust tiny bit. So basically like small strip was touched up very poorly. The clear didn’t match at all etc. I had managed to blend most of it in myself like a month ago buffing but still wasn’t perfect. So this happened my second go around at trying to cut through all the over spray and get down to the cars natural finish. I know car many years ago was in an accident front passenger side and maybe they painted that whole side after. Not sure.
    The natural finish is probably bad since they tried to fix it. Either that or the spray paint messed it up idk? The natural finish is probably messed up.
  4. #14
    Oct 2019
    Re: Clearcoat issue
    Any ideas on how to repair it?
  5. #15
    Member
    Jul 2014
    80
    Re: Clearcoat issue
    Depends on the results your trying to achieve but paint is the best option if perfection is your goal.
  6. #16
    Member Icarus's Avatar
    Oct 2019
    Ontario, Canada eh!
    65
    Re: Clearcoat issue
    Hmm, this doesn't make me want to try much of anything on the paint issue I have that's similar :/
    ·Ď˘ĺrµ§·
  7. #17
    Oct 2019
    Re: Clearcoat issue
    Quote Originally Posted by IH8SPM View Post
    what would other option be? I’ve painted my fender and I did it while on car. Despite same color you can tell in sun it’s been painted looks not as dark plus there’s a line you can see through the 2k clear where I tried blending it in with back part of fender. Should of done entire fender....
  8. #18
    Member
    Jul 2014
    80
    Re: Clearcoat issue
    You can't paint a single panel and expect it to match without blending it in to the others. Only way to achieve the result you want is to blend in panel to the others.
  9. #19
    Senior Member Rrthomas78's Avatar
    Dec 2017
    343
    Re: Clearcoat issue
    Mostly true but it depends on a lot things I just painted 3 of 4 panels on one side of my wife's car and i would challenge you to figure out which one i didnt
    Sent from my SM-A205U using Autogeekonline mobile app
  10. #20
    Dec 2017
    343
    Re: Clearcoat issue
    Quote Originally Posted by Rrthomas78 View Post
    I should have mentioned there was no blending
  1. Clearcoat Fracturing versus Clearcoat Failure
    By Mike Phillips in forum How to articles by Mike Phillips
    Last Post: 01-04-2016, 01:43 PM
  2. Clearcoat Options For Surfaces Without Clearcoat
    By Agribuff in forum Auto Detailing 101
    Last Post: 04-23-2015, 01:47 PM
  3. Clearcoat Burn Through - How to tell? Missing Clearcoat Strike-through
    By Mike Phillips in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-12-2013, 06:15 AM
  4. Clearcoat Issue
    By XJL in forum Ask Mike Phillips your detailing questions!
    Last Post: 05-01-2013, 03:11 PM
  5. Clearcoat Issue on '05 s2000 - Help
    By gt_nfr in forum Auto Detailing 101
    Last Post: 06-12-2008, 11:25 PM
» August 2020
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31 12345
