» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    Senior Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    4,226
    Re: Not happy with headlight results
    Quote Originally Posted by ItsKYRO View Post
    Used 3m wetordry sandpaper did all the sanding with water. Did swirl then horizontal on all 3 grits. Then used alcohol to clear off everything then did 2 coats of clear coat.
    I would not use alcohol on any acrylic lights or parts. I also wouldn't use anything below 800 grit.
  2. Likes Thomkirby liked this post
  3. #12
    Senior Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    4,715
    I finish with at least 3000 and sometimes 5000. Depending on how hacked up they were to start with, I rarely go any lower than 600. I then use a compound like Menz HCC 400 or Sonax CutMax and cut down those final sanding marks and haze. I then use a final polish like Menz 3500/3800 or Sonax Perfect Finish and refine what's left to a super fine gloss. Then spray a 2K clear.
    Typically, yes, clearcoat spray should serve to level out 2000 grit sanding haze but I've not been so lucky every time. I treat headlights like paint and refine it the best way I know before using 2K clear as my LSP. Like paint, I want it looking like glass before I lock it in.
    I will sometimes spray my 2K clear and hit that with 5000 and buff again.
  4. Thanks SWETM thanked for this post
    Likes SWETM, spazzz liked this post
  1. Meguiars Headlight Coating - innitial application results.
    By Eldorado2k in forum Product Reviews
    Last Post: 11-13-2018, 01:58 AM
  2. DP Headlight Restoration Kit vs Mothers NuLens Headlight Renewal
  3. 3m headlight kit results pretty impressed
    By dlepinski in forum Auto Detailing 101
    Last Post: 06-23-2013, 10:13 PM
  4. My results with the Turtle wax headlight restoration kit
    By Dugdug in forum Customer Comments
    Last Post: 10-19-2011, 10:51 PM
  5. Not happy with results...
    By jeffs42885 in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 08-19-2011, 02:08 PM
Members who have read this thread: 91
» September 2019
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 12345
