Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Jan 2008
    288
    SCRATCH X 2.0 AND DA polisher
    i have this stuff and haven't used it much other then few interior trim area that did ok on light scratches but didn't really do much. I know it has smat in it and light abrasive. Since i have this and never polished, is it pretty good way to try use it as polish with my da porter cable that has white pad that came with it (i have also 4 chemical guys finishing pad). It couldn't hurt right since it's probally least abrasive and I can see if any swirl marks get removed then go to a more aggressive pad and polish (any recomendation on what polish to get that's like next step from this (which isn't even a polish , not quite sure what it is lol)... Then I'll repeat and go next aggressive so forth until swirls are gone.
    i just used this on hard water stains on windows and worked good and thought i should use the whole bottle on something cause it will be waste not to use it even though only 11$.
    Jan 2015
    Simi Valley, CA
    1,783
    Re: SCRATCH X 2.0 AND DA polisher
    I've never tried ScratchX with a DA but if were in your shoes I'd have no hesitation to try it. Just try it out on a inconspicuous area like a lower section of the vehicle and see what the results are.
    And you mentioned that your not even sure what kind of product ScratchX is... Well it is a polish/compound. Although it's marketed as a product for "isolated" scratches, it's still a polish/compound and I see no reason that you couldn't use it on a complete panel or vehicle.
  3. Likes animescreen liked this post
  4. #3
    Super Member RTexasF's Avatar
    Jun 2006
    North TX
    2,582
    I'd say go for it but NOT with the pad that came with the DA. Frankly it's somewhat useless.
    Rick....now in North Texas
  5. Likes animescreen liked this post
  6. #4
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    The below “screen shot” was taken
    from this Mike Phillips posting/article:
    ScratchX - Consumer Market
    Hope this helps.
  7. #5
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by animescreen View Post
    polish with my da porter cable...
    and polish
    to get that's like next step from this...
    The below pictured Meguiar’s SMAT
    products is a linear representation
    of their aggressiveness order.
    The next step-up from ScratchX 2.0, in this
    aggressiveness order, is Ultimate Compound.
    {You can also see that ScratchX 2.0 isn’t the
    least aggressive of Meguiar’s SMAT lineup.}
  8. #6
    Jan 2008
    288
    Quote Originally Posted by RTexasF View Post
    Well i used the white pad on the my sunroof to remove water stains (water stain wouldnt remove ) and did great job. Why is white pad useless?
  9. #7
    Jul 2013
    Apex, NC
    1,283
    You could save it and use it for hand polishing the recess under door handles. I think that is probably it's most common use. I use UC to hand polish those areas.
  10. #8
    Jan 2008
    288
    Hope this helps.
    Yes Bob helps a lot!. Just getting around to the messages as working a lot these days (don't even have much time for car as much but all this new knowledge, i'll make some time lol). I do hear a lot about SMAT from meguiars and just wondering what is in simple terms? is pretty much just some abrasive that works wonders without affecting clear coat (just a guess)
  11. #9
    Jan 2008
    288
    Oh whoa, this is great, I always thought that scratch x was in bottom of the aggresiveness and less the swirl x too. .it's actually pretty up there. So from right to left it is least to most aggressive right? So pretty much , scratch x is a polish/compound as someone described it here. Guess Its bad idea to start with this as i thought it was least aggressive.
  12. #10
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    Everything you ever wanted to know about SMAT, and more. Courtesy of Mike P.
    The SMAT PACK - Everything you ever wanted to know about Meguiar's SMAT products...
  13. Thanks animescreen thanked for this post
  1. Replies: 9
    Last Post: 12-04-2019, 07:35 PM
  2. Griot's BOSS G10 Pneumatic Polisher - Air powered 10mm dual action polisher!
    Last Post: 04-08-2018, 09:52 PM
  3. Replies: 2
    Last Post: 06-11-2016, 09:19 PM
  4. Replies: 5
    Last Post: 10-06-2014, 02:28 AM
  5. Megs Scratch X and Nufinish Scratch Doctor
    By FMINUS in forum Auto Detailing 101
    Last Post: 08-03-2007, 02:53 AM
