» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Jul 2016
    3,091
    Re: Please help Identify staining/clear coat failure!
    I think I see what he's referring to. Starts up by the window (hard to see), but continues down where his hat and corner of phone are in the pic.
    Is this correct, fight?
    Yes exactly
    Jul 2016
    3,091
    This is the area I was referring to everyone sorry
  3. #13
    Jun 2009
    Stuart, Florida
    43,924
    When you polish the affected area
    1: Does it improve?
    2: Does it stay the same?
    3: Do you see any color coming off and onto your pad or towels?
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
  4. #14
    Oct 2006
    115
    Does your car get hit by sprinklers? Could be hard water deposits when the water from the sprinklers dry?
  5. #15
    Jul 2016
    3,091
    1: Does it improve?
    I'll have to check on these 3 things mike I think it may have gotten worse though. I kind of forgot about it when I polished a couple weeks ago.
    I just assumed it was going to go away and it didn't. Does it look like possible failure?
  6. #16
    Jul 2016
    3,091
    1: Does it improve?
    This weekend could I just run a 4" white rupes pad over it with a non abrasive paint cleaner like pinnacle lotion to see if the pad turns black?
    Would that tell me or do I need to use an abrasive polish?
    I recieved the M16 thanks so much. I'm going to read the article you wrote on applying it and try it asap.
  7. #17
    Jul 2016
    3,091
    OK so I can't post pictures right now but I've been monitoring this and I think it's Polish that sat on the paint too long. I think it got under the rubber trim and leaked out when it rained.
    Assuming it's Polish what would be the best product to use to try to get rid of it?
  8. #18
    Sep 2017
    Sweden
    2,490
    A wax remover would work I think or a panel prep wipe product. Just be carefull to not get the chemicals you use trapped under the trim. Use compressed air or a car blowdryer of some kind to blow the solution gets out or evaporate thoroughly. A longer bristle brush like the common detailing brush to aggitate where you can reach it. May need many applications and also flush it with water in between applications.
  1. Replies: 11
    Last Post: 05-03-2018, 02:35 PM
  2. Replies: 23
    Last Post: 06-28-2016, 10:12 AM
  3. Gloss Coat on Civic w/clear coat failure
    By Dan Deutsch in forum Product Reviews
    Last Post: 08-24-2015, 08:45 AM
  4. Is this clear coat/ sign of clear coat failure?
    By Aririguzo in forum Auto Detailing 101
    Last Post: 11-11-2014, 07:11 AM
  5. Replies: 9
    Last Post: 03-01-2012, 11:00 AM
Members who have read this thread: 70
» August 2019
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
