» Detailing Classes
Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 58
  1. #21
    Jun 2019
    110
    Re: The Best Product Ever!?
    Collinite 845
  2. Likes PaulMys liked this post
  3. #22
    Senior Member acuRAS82's Avatar
    May 2017
    Pittsburgh PA
    2,246
    Collinite 915. Best product all around that I can think of, with value considered.
  4. #23
    Senior Member ScottH's Avatar
    Nov 2015
    Northern NJ
    893
    Soooo hard to narrow down to just one! Letís just say I canít count tonight ok?
    Collinite 476 - nearly bulletproof protection that would take a ceramic coating to best in protection.
    Griotís Best of Show Detail Spray. Unreal shine and protection in one. Almost too easy to use
    McKees Tire and Rubber Rejuvenator - you cant get your tires any cleaner
    ScottH
  5. Likes PaulMys liked this post
  6. #24
    Sep 2017
    Sweden
    2,930
    Carpro Reset car soap as it's gives you lubrication and the cleaning ability is top notch.
    Bilt Hamber Auto-Foam. No other prewash comes near this in cleaning ability. I often wondering if after the cleaning with the PW if it was necessary to do the bucket wash afterwards. The rinse bucket is almost clean every time I used it. It's when it's going long between the washes during the winter months I can see a slightly dirty rinse water.
    Sonax Glass Cleaner is awesome on the inside of the windows. It's ability to cling on the glass makes it to not leave so much of run off and overspray. The cleaning ability is also great both on the inside and outside. On the outside windows the Angelwax Vision glass cleaner is beating the Sonax in cleaning ability but not a product for the sensitive to smells LOL.
    Sonax Brilliant Shine Detailer. For being a QD and the extreme water behavior you get from it and long longevity from it. It's an extreme product in this range of products. Then it has it's drawbacks with not the slickest finish and sometimes finicky application. But when you experience the awesome parts it's forgiven LOL.
  7. Likes ScottH liked this post
  8. #25
    Aug 2010
    Fairmont, MN
    3,188
    Whether itís the present day, or the past:
    Go ahead...Name the detailing task;
    Meguiarís has always had the products
    that I can best describe as Ēkick-assĒ!
    {IMO: Thatís the reason why they
    have been around since 1901...}
    Agree!
    Bill
  9. #26
    Senior Member swanicyouth's Avatar
    Mar 2011
    Limerick, PA
    9,385
    Over the years so much stuff has came and went. Some of itís still around - but just isnít use a lot; even though itís a good product. I canít isolate one product as the best - but here are some all time favs in no real order.
    1. Tuff Shine Tire Kit
    First tire coating in my world and still the only stuff I use. Both the cleaner & coating are pretty unique in what they do. One of the few thing out there that lives up to claims.
    2. P21S/S100 Wax (any)
    Was the first real fancy type wax in my world. It has a a great blend of ease of use, reasonable cost, good looks, and a smooth as butter user experience all the way from Europe. Itís same quality as many beauty waxes costing hundreds $.
    3. CarPro Hydrofoam
    First, and may still be? only product that can be used as a soap and protectant in one. Water beading is legit. This product doesnít get accolades, I think mostly because itís poorly marketed and understood. Basically, donít try and use it on paint outside or itís going to spot. Use it in a spray bottle to clean well maintained wheels and trim & clean & protect in 1 step.
    4. Chemical Guys Honeydew Snow Foam
    First shampoo I recall specifically being sold as ďsnow foamĒ. Smells amazing, not too costly, and makes a ton of foam. Like most of these snow foam products, it probably does little if anything; but itís still fun to use.
    5. Sonax BSD
    Still may be the best stuff out there you can spray on paint and get protection. Again, another case of bad marketing. Should have been labeled a spray sealant. Best overall stand alone LSP that doesnít wash off after 2 rain drops. Cheap & easy.
    6. Megs Wheel Brite
    Still may be best working wheel cleaner out there. Cheap and outperforms any iron wheel cleaner. Also, safe on factory wheels if directions followed.
  10. #27
    Jan 2014
    890
    Toss up for me. Either Sonax BSD or P21s Total Auto Wash.
    This is all assuming you don't consider d-limonene a 'product'.
    Knock some P21s down 30:1 with distilled water in a pump sprayer (You might even be able to dilute it further. I haven't tried ). Try it to clean your tires/wheels, engine compartment, the lower edges of panels, anything that gets a lot of traffic film. It's safe like a car wash, but cleans like harsher chemicals.
  11. #28
    Aug 2014
    1,435
    Quote Originally Posted by ducksfan View Post
    Is it similar to a degreaser?
    "I've seen a good quality car wash look better than some guys complete detail jobs."
    Mike Phillips 10/21/09
  12. #29
    Aug 2014
    1,435
    Iron-X; I love watching orange dots melt & rinse away.
  13. #30
    May 2013
    192
    Opti Coat before it went professional
  1. 15% Off and a New Product!
    By Elliot@Autogeek in forum Sales & Promotions - For forum members and non-forum members
    Last Post: 04-25-2018, 01:21 PM
  2. Best AIO Product?
    By Rob T in forum Auto Detailing 101
    Last Post: 09-24-2010, 07:29 PM
  3. Got the Wrong Product. Because I Ordered the Wrong Product. DOH!
    By oldmodman in forum Ask Mike Phillips your detailing questions!
    Last Post: 04-14-2010, 09:08 AM
  4. A little product help
    By Gol10dr in forum Auto Detailing 101
    Last Post: 01-28-2008, 09:13 PM
  5. What product to use
    By carguy in forum Auto Detailing 101
    Last Post: 01-27-2008, 06:53 PM
Members who have read this thread: 11
» July 2020
