Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Super Member ScottH's Avatar
    Nov 2015
    Northern NJ
    895
    Compound with the most cut
    Dear Forum Members,
    What is your go to compound that you consider to have the most cut/bite? Also, how would you rate that compound in terms of its ability to finish? (e.g. do you typically have to polish down or have you stopped after using your favorite cutting compound?)
    Reason I ask: I did a massive F350 today that was COVERED in thousands and thousands of etched in water spots. It took over 8 hours just to correct the paint, with at least half that time to remove the water spots. FYI: I used McKee's 37 Fast Cut Compound this time around, and was wondering what you all use. I also have Griot's FCC and love it. It finishes down well but was wondering if you all know of something with more cut than these two.
    Left side after compound. Right side untouched.
    P.S. I will post more pics in the Show and Shine section.
    Many thanks!
    ScottH
    Attached Thumbnails Attached Thumbnails Compound with the most cut-img_1113-jpg
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Re: Compound with the most cut
    My new favorite is now Sonax CutMax. I've been using Menz HCC 400 for years and will still keep a bottle of it but CutMax blew me away. They both finish down really nice too. I'd give the edge to Menz on the finish scale.
    There are certainly more aggressive compounds out there but Menz 400 or now Sonax CutMax with a wool pad and my rotary are all I ever really need and even wool/rotary is rare for me. If I was looking at bad water etching on hard Ford paint I probably would test CutMax, rotary and wool.
    I vary the bite by changing pads or machine.
  3. Thanks ScottH thanked for this post
  4. #3
    Jun 2019
    110
    I use Griots FCC. So many products on the market i wonder how many products are the same thing, just a different label.
  5. Thanks ScottH thanked for this post
  6. #4
    Dec 2018
    7,170
    I’ve recently used Griots FCC and CP clear cut. FCC is great and works well. If you looking for most aggressive though, clear cut is it. Way to aggressive for a rookie like me.
  7. Thanks ScottH thanked for this post
  8. #5
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Usually Menzerna FG400 or Rupes Zephir is enough for me.
    Megs M100 on microfiber is still very potent too.
    I'm very interested in 3D ACA500 though.
  9. Thanks ScottH thanked for this post
  10. #6
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    IMO the best combo is either a Flex 3401 or Rupes Mille with CarPro Clear Cut and some purple/blue wool pads. That's my go-to for super cut and great finish out thus minimizing the time for refining with a polish.
    2023
  11. Thanks ScottH thanked for this post
  12. #7
    Nov 2015
    Northern NJ
    895
    Thank you all for the recommendations. Is Sonax cut Maxx or CarPro Carpro clear cut worth twice the price of griots fast correcting cream in your opinions ? Are they low to no dust like FCC?
    PS is FCC silicone free?
    ScottH
  13. #8
    Dec 2007
    Tampa Florida
    5,274
    Great question, Scott, and I'm pretty frugal with my business expenses.
    I have found I use less product with Sonax vs Menzerna. Not much but certainly less per job. I start with 3-4 small drops and then add only 2 dots to continue. That makes it last a long time and I consider that.
    The other thing that impressed me is it dusts even less than Menz...not that Menz is a dusty product either.
    I have heard, read and seen outstanding results from Griot's FCC and will give it a good test run this summer but for now I'm a Sonax cutter.
  14. Thanks ScottH thanked for this post
  15. #9
    Feb 2014
    Rochester MA
    2,627
    Fast correcting cream with a microfiber cutting pad on my 21mm is pretty legit.
    Also IGL F1 with the same setup is a heavy cut and easy wipe down.
    M100 can be a bit heavier depending on the paint.
    IGL Authorized Coating/Kenzo Installer
    Final Inspection Auto Detailing- https://www.facebook.com/FinalInspection
  16. Thanks ScottH thanked for this post
    Likes Paul A., DetailTrail liked this post
  17. #10
    Apr 2015
    PGH, PA
    1,482
    Scholls concepts S0
  18. Thanks ScottH thanked for this post
    Likes TTQ B4U liked this post
  1. Meguiars ultimate compound vs clear coat safe rubbing compound
    By bmwstephen in forum Auto Detailing 101
    Last Post: 06-07-2015, 06:51 AM
  2. Replies: 4
    Last Post: 08-02-2013, 08:28 PM
  3. Optimum Huper Compound Spray vs. Meguiars Ultimate Compound??
    Last Post: 12-17-2010, 08:09 AM
  4. What's the difference between Optimum Hyper compound and Compound II?
    By O.C.Detailing in forum Ask your detailing questions!
    Last Post: 10-17-2009, 10:31 AM
  5. Replies: 0
    Last Post: 06-01-2006, 01:21 PM
