» Detailing Classes
Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
  1. #31
    Senior Member AaronE's Avatar
    Sep 2018
    138
    Re: Deep talk about wheel cleaners - alkaline, acid, pH levels
    I'm curious to buy some litmus strips to test the dilution ratios. I believe the SDS only covers the concentrate, not the reduced.
    Sent from my SM-G950U using Autogeekonline mobile app
  2. #32
    Senior Member UncleDavy's Avatar
    Aug 2017
    Taunton, MA
    1,068
    Quote Originally Posted by AaronE View Post
    No need for litmus strips. Just use this formula.
    For an acid: Original pH + (-log(original volume/new volume))
    For a base: Original pH - (-log(original volume/new volume))
  3. Likes PaulMys liked this post
  4. #33
    Sep 2018
    138
    Quote Originally Posted by UncleDavy View Post
    Now that is cool! I'll run some calculations later
  5. #34
    Aug 2017
    Taunton, MA
    1,068
    Here is an easy online calculator.
    Chemical Calculator: Dilution of Bases and Acids
  6. Thanks BillE thanked for this post
    Likes AaronE liked this post
  7. #35
    Jul 2019
    I have a jug of Meguiars Wheel Brightener that i haven't opened yet and was wondering if anyone would know if it is ok to use on my rims Enkein Nt03+M?
    Just a bit confused to what I can use it on besides Stock rims on cars.
    "MAT Technology
    Enkei developed a new manufacturing process to produce the next aluminum wheel generation. The Most Advanced Technology (M.A.T) combines one-piece cast wheel technology with a rim forming technology called spinning process. Using this new technology of casting and rim forming by M.A.T process, is critical to improve drastically the material property and strength of the wheels. Rim-Rolled technology shapes the rim to improve material elongation without sacrificing the wheels hardness."
    Deep talk about wheel cleaners - alkaline, acid, pH levels-enkei-nt03-info-jpg
  8. #36
    Member DirtyCanuck's Avatar
    Jun 2019
    Ontario, Canada
    66
    Just to give you an Idea as to what you are working with. Household bleach (javex,Clorox) is right around 12 ph full strength. At 13-15 you are getting quite alkaline (lye).
    On the other end of the scale is acid. Think vinegar ph 3-4, or hydrochloric acid. Ph 0-1
  9. #37
    Sep 2018
    138
    Quote Originally Posted by KrisDetails View Post
    "MAT Technology
    Depends on the alloy they are made from. Some react with different alkalines and acids but not others.
    If you want to know for sure, check the acid type in the Wheel Brightener then call your wheel manufacturer and ask about if it's safe or not.
  10. #38
    Senior Member Belo's Avatar
    Jul 2014
    Rochester, NY
    486
    Quote Originally Posted by Mike lambert View Post
    Modern iron and fallout removers are the way to go. PH neutral and work very well for wheels and paint. Also no damage to surrounding areas such as brake components or anodized trim, such as running boards or wheel arch trim.
    except for the iron removers explicitly state to keep away from calipers and bare metal brake components...
    2009 Pontiac G8GT
    2015 Ford Explorer Limited
    2019 Chevy Silverado RST Z71
  1. High alkaline? Mckees foaming gel wheel cleaner?
    Last Post: 01-21-2018, 12:48 PM
  2. Stain Theory? Alkaline and Acid Based Stains
    By RMarkJr in forum Ask Mike Phillips your detailing questions!
    Last Post: 07-25-2017, 02:22 PM
  3. Critical Details: Lets Talk Steam Cleaners
    By CriticalDetails in forum Auto Detailing 101
    Last Post: 05-21-2016, 07:29 AM
  4. PH levels and cleaners
    Last Post: 08-21-2013, 06:16 AM
  5. Alkaline wheel cleaners and clear coated wheels?
    Last Post: 12-02-2012, 09:00 PM
Members who have read this thread: 9
» July 2020
