» Detailing Classes
Results 21 to 30 of 38
  1. #21
    Senior Member Eldorado2k's Avatar
    Nov 2015
    Los Angeles, California
    11,216
    Deep talk about wheel cleaners - alkaline, acid, pH levels
    Quote Originally Posted by yakky View Post
    That applies to brand new we wheels... Maybe. But in real life there are scratches and/or curb rash which means bare aluminum. Even on brand new wheels there is bare aluminum somewhere. I've seen bubbling around valve stems on cars where owners regularly used agressive products on wheels.
    IMO wheel cleaners are one time use on neglected wheels. They are not for regular use to save you from bending over and using some elbow grease.
    The kind of bubbling youíre talking about isnít caused by aggressive wheel cleaners, itís caused by long term neglect aka baked on brake dust which can eat through the finish similar to how bird crap can eat through your clear coat if left to bake for long enough.
    ...But if and when thereís any damage to the wheels finish, it isnít caused by the wheel cleaner, not even Wheel Brightener @4:1 will do any harm and the following pics of my own wheels can prove it.
    Hereís the chrome wheels on my Cadillac several months ago, when I 1st bought it. The whole car was severely neglected for what mustíve been years. Just look at that baked on brake dust. Keep in mind these chrome wheels are 17yrs. old.
    Odds are thereís bound to be some pitting or bubbling 1 way or another right?
    If thereís no pitting or bubbling from the years of that baked on brake dust, then the Wheel Brightener is about to cause it because if itís not caused by the brake dust itís about to be caused by the wheel cleaner right? After all, itís Acid! Oh no my wheels!Deep talk about wheel cleaners - alkaline, acid, pH levels
    ...Actually, no. Of course the wheel cleaner didnít cause any damage. It actually restored them to like new. Yes, even though itís ďacidĒ based.
    I use Wheel Brightener once per week to clean my wheels. And if it wasnít Wheel Brightener it was itís OTC equivalent Megs Hot Wheels Chrome Wheel Cleaner or Eagle 1 Chrome & Wire Cleaner for the past 20+yrs. on all of my Cadillacs on a weekly basis because theyíve all had chrome wheels and the acid based wheel cleaner Never caused any damage.
    This is my weekly routine.
    WB for wheels
    Megs D114 for the tires
    Megs APC for the wheel wells
    Clean.
    And as far as road rash & scratches that may be on wheels exposing the so called delicate Ďbare aluminumí...
    Nothing happens.
    Iíve cleaned countless customers wheels with so called aggressive wheel cleaners and have never had a single issue and a whole lot of those wheels have road rash on them and if they donít theyíll have it soon because normL people eventually scratch their wheels.
  2. #22
    Jul 2013
    Apex, NC
    1,283
    Re: Deep talk about wheel cleaners - alkaline, acid, pH levels
    How else do you explain that white worming affect? It always seems to start where the wheel has been chipped from road rash or from the impact socket at the wheel lug holes. It always looks like a strong cleaner has worked its way underneath the clear and or powder coat.
  3. Likes yakky liked this post
  4. #23
    Nov 2015
    11,216
    Quote Originally Posted by DBAILEY View Post
    Iíve never heard of that term. These wheels had lots of the clearcoat peeling off of them + road rash. Is the worming effect that youíre referring to seen here?
  5. #24
    Jul 2013
    Apex, NC
    1,283
    I am not see any of your photos in either post unfortunately
  6. #25
    Mar 2015
    I know exactly what you're talking about. It stems from exposed aluminum either at the backside where it sits on the hub or around chips/rashes as you mentioned.
    I suspect it's from corrosion of the aluminum spreading and lifting the clearcoat. I'm sure aggressive cleaners and road containments (e.g. sodium chloride for snow/ice) contributes to it. Though as one of my concerns from my original post, I do wonder if certain pH level of wheel cleaners will accelerate that corrosion.
  7. #26
    Senior Member AaronE's Avatar
    Sep 2018
    138
    Quote Originally Posted by SayNoToPistons View Post
    Coming from a small understanding of aviation grade aluminum, that same effect happens to all aluminum over time, you just have the luxury I suppose of seeing it develop compared to on my plane where it can be hidden under the paint. A chemical too acidic or too basic will cause damage.
    Mind you, different aluminum alloys have different tolerance levels of what they can take to some degree. Here's a guide from an FAA circular. I selected this portion dealing with the chemical effects of corrosion but if you Google FAA Advisory Circular 43-4B, that is the latest guidance for aluminum corrosion and control and can shed some light on what causes corrosion in aluminum and why some wheels will be more or less resistant than others.
    Sent from my SM-G950U using Autogeekonline mobile app
  8. Likes BillE, SWETM liked this post
  9. #27
    Aug 2010
    Fairmont, MN
    3,189
    Well stated...I TOTALLY agree.
    It seems that it only takes one tiny 'thin spot' is to get things started. At least that's been my experience.
    Bill
  10. Likes AaronE liked this post
  11. #28
    Dec 2006
    795
    Don't you live is southern California? Aside from UV, it's the most friendly environment for cars.
    The chemistry is there. Reactive aluminum plus strong acids/bases. I just can't see how you think it doesn't happen.
  12. #29
    Sep 2018
    138
    Eldorado is a pretty respected guy and he's give me some solid advice here (thanks make keep it up!) But like that advisory circular states (please take a look if you want to nerd out and get a deeper understanding) different alloys of aluminum react to different PH levels and, I forgot to mention, different types of acids. Also it depends on if there's a coating or not, anodization, alan clad, etc. It's way more than I can understand but when I go to the base in two weeks, maybe I can swing by the airframe shop and talk to a few of the metal heads about this.
  13. Thanks Eldorado2k thanked for this post
    Likes SWETM liked this post
  14. #30
    Apr 2013
    1,266
    I donít even think wheel bright is that strong in 4:1. Itís cleans my silver oem wheels pretty well but not my black oem or aftermarket that well unless you like to agitate
  1. High alkaline? Mckees foaming gel wheel cleaner?
    Last Post: 01-21-2018, 12:48 PM
  2. Stain Theory? Alkaline and Acid Based Stains
    By RMarkJr in forum Ask Mike Phillips your detailing questions!
    Last Post: 07-25-2017, 02:22 PM
  3. Critical Details: Lets Talk Steam Cleaners
    By CriticalDetails in forum Auto Detailing 101
    Last Post: 05-21-2016, 07:29 AM
  4. PH levels and cleaners
    Last Post: 08-21-2013, 06:16 AM
  5. Alkaline wheel cleaners and clear coated wheels?
    Last Post: 12-02-2012, 09:00 PM
Members who have read this thread: 10
» August 2020
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31 12345
