Tire coating and ceramic on wheels
I’m pulling off the wheels to ceramic the barrel and spokes with CQUK. I also will apply Mckee’s Tire on the rubber while off.
just curious if there’s a right sequence to doing this? I assume because CQUK needs to cure 24h, it should be last to avoid any water or contaminants?
Was planning to;
pressure wash entire wheel
IronX
McKee rejuvenator on rubber,
clay bar wheels
Mckee tire dressing
CQUK x 2
then probably Gliss
Re: Tire coating and ceramic on wheels
Clean the tire and wheel first. Then coat both. Doesn’t matter which is coated first.
If you are gonna clay, you should also polish.
I would do the ceramic coating first.
Thanks. Great pint as they’re black wheels. I’ve never polished wheels, but assume just hand application pad? I only have M205 but assume that’s fine with eraser after.
Was planning to;
IronX
clay bar wheels
Mckee tire dressing
CQUK x 2
then probably Gliss
I did that same exercise last summer but used CarPro DLUX on the wheels. Sequence close but suggest you do use Eraser prior to applying the CQUK.
Modify you thoughts and try these
Ironx
Clay Bar
Polish any defects
APC on wheels and tires again
Now coat both sides of the tire (easiest now) with McKees
Set tire up and use the Eraser or good Paint Cleaner of your choice
Wipe dry
Apply coatings front and back
Put wheels onto truck
Let cure at least 1-2 hours but I let mine sit overnight.
I use the Reload every few months on the front of wheels (McKee's Hydro Blue is alternate). Use only car soap on the wheels during wash unless need aggressive cleaners.
Enjoy the coated wheels. Easy to clean and do shed more dust and debris but they will still attract road grime just like the car.
Ya, that will work. You can also get a polishing ball that attaches to the drill, they cost like 20$ and many brands including Mothers make them. ŕ
By dlefty in forum Auto Detailing 101
Last Post: 09-01-2019, 09:13 PM
By ronnieh1 in forum Auto Detailing 101
Last Post: 08-05-2018, 10:30 PM
By minirips2 in forum Auto Detailing 101
Last Post: 05-13-2018, 07:15 AM
By high class detail in forum Ask your detailing questions!
Last Post: 04-24-2017, 09:33 AM
By GlossAngeles in forum Show N' Shine
Last Post: 12-15-2014, 12:28 PM
