» Detailing Classes
Results 1 to 10 of 10
    Dec 2010
    Calabash, NC
    9 month old corvette
    Going to work on a NEW (9 months old) gray corvette next week. Was planning on using either BF One Step or HD Speed, topped with BF SiO2 or Opti-Seal. Am I on the right track, or missing the boat entirely? Suggestions welcome.
    Phil
    Dec 2011
    Reisterstown MD
    1,083
    Re: 9 month old corvette
    Don’t know about those specific products but look it over carefully. I’ve found all the new ones I’ve done have sanding marks from the factory, and depending on the dealership it came from, the damage caused by an attempted repair.
    Senior Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    20,066
    Quote Originally Posted by Phil_M View Post
    IMO:
    Performing “Test Spot(s)”, with either one
    (or both) of the correction products you
    listed, will go a long way in determining if
    you’re on the right track, or not.
    Afterwards:
    The BF SiO2 or Opti-Seal will be
    the icing on the cake.
    Jun 2009
    Stuart, Florida
    43,839
    Phil
    I think this is an awesome way to take care of any car.
    KISS = Keep it Simple Simon
    I just did this Corvette with Pinnacle Jeweling Wax and people ket asking me,
    What ceramic paint coating did you use?
    Review: RUPES Mark III BigFoot 21 Polisher by Mike Phillips
    And down the road if there were any marring, bird droppings, accidental swirls from washing or wiping I could quick and easy fix by just doing the same thing - using a one-step cleaner/wax.
    With a coating it gets a lot more complicated and the average person cannot do it correctly.
    Just about anyone with any orbital can use a product like Pinnacle Jeweling Wax, BF One Step or 3D Speed without any skill or talent and get this same result.
    Mike Phillips Facebook Page
    Twitter
    Instagram
    Mike Phillips Detail Files YouTube Playlist
  5. Likes PaulMys liked this post
  6. #5
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    4,927
    Exactly.
    I am glad to hear this from you, Mike.
    I hope all newbies will take this to heart. Coatings are great for those who are fans of them, but if you're just starting out with paint correction.... Check out this 'Vette.
    My point is, all of the info here will naturally gravitate the new guys toward coatings as the newest/greatest thing (which they are to a point).
    But, a good old sealant and/or wax can provide incredible results as well.
    Just my opinion..........
  7. #6
    Jun 2009
    Stuart, Florida
    43,839
    Phil
    Hey Phil,
    Have you made a decision on which way to go?
    Twitter
    Instagram
  8. #7
    Dec 2010
    Calabash, NC
    Yes indeed.
    I took your advice and ordered the Pinnacle Jeweling Wax. Should arrive by Thurs.
    Will let you know how it turns out.
    Thanks again
  9. #8
    Jun 2009
    Stuart, Florida
    43,839
    Yes indeed.
    Thanks again
    Cool. I'm excited to hear back your results.
    What type of polisher and pads do you have?
    Twitter
    Instagram
  10. #9
    Dec 2010
    Calabash, NC
    I have a PC 7424XP and planning on using LC CCS Green Pads
    Sound ok. - Looked a car yesterday and could not see any defects - of course it needs a good wash.
    I'm just a small guy that does vechicles in spare time - mostly neighborhood clients. Enjoy the heck out of it.
  11. #10
    Jun 2009
    Stuart, Florida
    43,839
    Thank you for the above info. I wanted to add some more info that I think would help you but didn't want to waste your time. I believe you will find the information in the below articles helpful or at least a resources if you should run into any problems.
    How to correctly use an AIO or Cleaner/Wax by Mike Phillips
    Good rule of thumb when using an AIO - stick with foam polishing pads by Mike Phillips
    The Definition of a Section Pass by Mike Phillips
    Tons of info here and a great video that is clear and precise on how to use the Porter Cable.
    Here's what you need to get into machine polishing - Recommendations for a beginner by Mike Phillips
    And last but not least
    Lots of pads
    You also need lots of pads. Just like using a compound to correct a car's paint, when using a one-step cleaner/wax you need a lot of buffing pads. When using a product heavy or wet the pads are going to become wet or soggy fairly quickly. When a foam pads become wet it becomes USELESS. This means you're wasting time and in most cases destroying the pad as a wet pad hold in heat more than a dry pad. It will also take you longer to buff out a car because the pad is no longer doing correction work. And to top it off, your results won't look as good than had you switched to a clean dry pad often.
    I recently used a jeweling wax, (like a cleaner/wax only finished out better and more consistently on a wide spectrum of paint types), and look how many pads I used to do the job a fast as humanly possible while working safely and maintaining pro results.
    As you work around a car your pad gets soggy and wet from repeated applications of the products you're using. Wet pads don't work well. Cutting pads quit cutting. Polishing pads quit cleaning.
    Twitter
    Instagram
  12. Likes custmsprty liked this post
  1. 10 Month Update - BLACKFIRE One Step - BLACK 700 HP Hennessy Corvette
    By Mike Phillips in forum Blackfire Wax Products
    Last Post: 06-06-2019, 09:56 PM
  2. Replies: 18
    Last Post: 03-09-2015, 02:53 PM
  3. PBL at one month -- Take 2
    By kevincwelch in forum Off-Topic
    Last Post: 07-13-2014, 11:01 PM
  4. 11 month old PC crapped out
    By Chase.Barnett in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-31-2013, 05:26 AM
  5. Only one month into 2012 and look at all this...
    Last Post: 02-10-2012, 09:44 AM
Members who have read this thread: 81
» August 2019
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
