Re: Optimum Tire Protection Coating (TPC)
Nice review.
I had a not so great experience with the optimum tire coating.
This is my second tire that looks like absolute trash after application. I’m not sure what I can really do differently at this point, as all my tires have been scrubbed, cumulatively, about 8 times with straight power clean.
Almost as soon as the coating touches my tire it dries out and I can’t really spread it around, leading to this streaky horrible appearance.
I don’t know if it’s my tires or what. The first one I applied it to in about 40 degree weather, so I blamed that on me. But it’s 60 today, and I was in the shade. So I’m really at a loss here as to what I could be doing wrong.
Not really looking forward to doing my last two tires If this will he the end result, lol. It’s sad when my tire just looked a lot better without anything on it at all.
Originally Posted by
Finick
Are you spraying on tire or applicator?
Coatingsarecrack
I used an applicator. It’s really weird, it just dries so damn fast on the tire. Like I almost want to say within 5-6 seconds it seems like it’s tacky and you can’t spread it without streaking it.
I imagine if I sprayed it I wouldn’t have any issues.
Edit: to put it into context, you had enough working time to use the brush then level it with the microfiber applicator pad? If I started applying at the top of my tire, before I even got to the bottom of the tire it was already black. It would be impossible to have a blue hue all over the tire based on how fast it dries. Unless I used a ridiculous amount, and I already used a ton on that tire. Much more than I’ve seen other people use.
Finick
Sounds like it’s being absorbed or partially by the rubber.
Either the compound it’s self or partly the cleaning process.
Some tires behave this way and need to use the alternate type of dressing (water/solvent).
Also used this (rim brim) to protect rims during this and works pretty well. East to use: has to clips that fit in between tore and rim to center. Was perfect fit. Durable: at first I thought was flimsy but after stepping on it a couple times I understand why now. Bent but didn’t break.
WristyManchego
Yeah I was thinking the same thing. If I can figure out how to scrub the crap off I may just clean my tires and leave them naked moving forward. I really hate applying tire dressing lol.
Finick
Maybe try tac systems or McKee’s ? The seem to be polymer/resin and I believe solvent based maybe? Optimum doesn’t mention resin and is water base. May be different type of coating so maybe different results?
