Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
    Apr 2017
    39
    Re: Tire dressing help
    In spray form for tires like you describe had good luck with Stoner Tire More Shine, Just my .02
    Super Member Goonie75's Avatar
    Feb 2017
    696
    Quote Originally Posted by Goonie75 View Post
    Optimum Opti-Bond Tire Gel. Need to try 253 for that. Use it on ext trim... hmmmm.
    Sent from my SM-G965U using Autogeekonline mobile app
    My bad... Tire dressing help we use 271 for ext trim but do want to try 253...
  3. #13
    Dec 2018
    7,157
    I really liked CP Perl. If your looking week to week will be great. This after cleaning with griots rubber cleaner and one coat peRL
  4. #14
    Super Member pickles's Avatar
    Jun 2011
    477
    Quote Originally Posted by VinFX4 View Post
    Looking for a tire dressing that is not oily or very wet looking. It has to be in a spray bottle because these are truck tires with a very aggressive sidewall. I can’t stand the super shinny dirt attracting used car lot look. (Not that there’s anything wrong with that). What products do you guys recommend?
    CG silk shine or PERL. Cut either one 1:1 with water for that satin black new tire, not wet oily tire sheen.
  5. Likes Coatingsarecrack liked this post
  6. #15
    Super Member VISITOR's Avatar
    May 2007
    9,721
    PERL 1:1 tires/trim, 3:1 for wheel wells/engine, and you can also use it for interior as well. one of my top ten detailing products for sure...
  7. Likes Coatingsarecrack liked this post
  8. #16
    Super Member Breese147's Avatar
    Dec 2014
    Germany currently,Texas previously
    452
    Tip for applying tire dressings to aggressive side walls is to get a shallow and small Tupperware container (or if you’re in a pinch just cut out the bottom of a water bottle) and pour/spray your dressing in to there and use a detail brush to apply it. Much easier to control its application without overspray and easy to get it into all the tread without using a ton of product. Afterwards quick wipe down with MF towel and you’re good to go.
  9. Thanks The Guy thanked for this post
    Likes The Guy liked this post
  10. #17
    Apr 2013
    1,266
    For weekly sprayable product: in no particular order. Poorboys bold and bright. Duragloss 253, carpro Perl, many of the tire aerosols at the store work just fine too.
    Megs all season may be a little too heavy for weekly use IMO. I used it on many occasions on tires and I actually like it on my weathertechs but it will make them slick for a few days
    Everyone has a different look they like most don’t last in the rain well at all but being weekly. Also tires react differently a set a Michelin’s on a passenger car may look very matte while a Continental on a different car will look much more glossy
  11. #18
    Apr 2013
    1,266
    Quote Originally Posted by Breese147 View Post
    Good tip I’ll have to try it come spring
  12. #19
    Super Member Boudin's Avatar
    Mar 2012
    Southeast Louisiana
    453
    Griots black Satin aerosol
    Carpro pearl diluted to your desired sheen
    Mck37 SiO2 enhanced Tire Shine
    On truck tires I usually reach for the Griots aerosol
    Sent from my SM-G965U using Tapatalk
  13. #20
    Aug 2013
    St Louis metro (Illinois)
    5,805
    You should like 253 much better. I've used 253 for many years and picked up a small bottle of the Optimum when my 253 bottle ran out as I wanted to get some experience with other products. I've been really disapointed. I'm not impressed by the appearance of the Opti-Bond, and it doesn't survive a single encounter with rain or snow.
    Funny experience with the Opti-bond as an example: One day I spent a great deal of time last spring detailing my car top to bottom including a very careful application of the Opti-bond. It was one of the few times it actually looked really good on my tires and I was quite satisfied when then sun went down. Overnight we had a horrific thunderstorm pass through which blasted the passenger side of my car with rain. The next morning, the driver side tires still looked pretty good without only a few rain streaks, while the passenger side had bare tires. The product has been totally washed off as if nothing had ever been applied.
    I want to try PERL when my Opti-bond runs out, but I wonder if it will live up to my 253 experience.
  14. Thanks Goonie75 thanked for this post
    Likes Goonie75 liked this post
  1. Replies: 16
    Last Post: 04-09-2019, 12:43 PM
  2. Replies: 31
    Last Post: 05-27-2018, 12:06 AM
  3. Replies: 29
    Last Post: 05-26-2018, 09:13 PM
  4. Meg's D160 All Season Dressing as tire dressing?
    By 7.3powerstroke in forum Products Guides
    Last Post: 03-24-2016, 08:48 PM
  5. Replies: 12
    Last Post: 11-27-2013, 09:20 AM
