Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Regular Member Black Bowtie's Avatar
    Aug 2014
    Johnston, Iowa
    106
    Re: Cloth fender liner cleaning
    You can get plastic wheel liners for the rear. I have not seen them for the front.
    2018 Chevy Silverado 1500 Rugged Rear Wheel Well Liners - RealTruck.com
  2. #22
    Nov 2015
    Los Angeles, California
    13,750
    Quote Originally Posted by Black Bowtie View Post
    I think it’s because basically all trucks come standard equipped with plastic wheel wells on the fronts.
  3. #23
    Mar 2011
    PA
    5,788
    I am now dealing with these on my ZR2. A area that once was taken care of with hyperdressing 1:4 on the normal plastic ones. Well, I have been using 3D Yellow degreaser 1:4 on the fabric ones. I spray them with the 3D and let them dwell a bit. Then hit them with a strong jet of water. So far this has been working. Needless to say, I have a lot of hyperdressing going nowhere. But I will find other uses for it.
    UPDATE: I have now read other posts that some members are actually spraying the hyperdressing on the felt liners after cleaning. I have not tried this yet. And don't know if their would be any benefit of doing so?
    2018 Colorado ZR2
  4. #24
    Jan 2019
    California
    287
    I've read that mixing fabric softener 1:4 with water in a spray bottle makes a solution that helps brush material out of there. I haven't tried it yet.
  5. #25
    Super Member wdmaccord's Avatar
    Jun 2013
    West Des Moines, IA
    1,278
    I have pretty good luck using a pressure washer. It seems to get the grass out. It just takes time...especially if I haven't given them a good powerwashing in a while. I usually just keep going until I see the water running clear out of the well. The first spring wash is usually the worst after a long winter.
    2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
    2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
    2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
  6. #26
    Super Member Goonie75's Avatar
    Feb 2017
    696
    Pressure washer... brush... rags... scotch guard... not sure it helps a lot but cant hurt
    Sent from my SM-G965U using Autogeekonline mobile app
  1. Carpet dye for cloth fender liners?
    By briarpatch in forum Auto Detailing 101
    Last Post: 01-16-2021, 09:47 PM
  2. Cleaning Fender wells (liner under the fender)
    By TNMIKE46 in forum Auto Detailing 101
    Last Post: 01-23-2019, 04:15 PM
  3. Cloth fender liner cleaning
    By ohten in forum Ask your detailing questions!
    Last Post: 12-15-2017, 07:18 PM
  4. Roadkill remnants on plastic fender liner
    By briarpatch in forum Ask your detailing questions!
    Last Post: 04-25-2016, 05:54 AM
  5. head liner cleaning
    By Craig in forum Auto Detailing 101
    Last Post: 08-21-2009, 01:01 PM
