Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 51
    Jan 2018
    61
    Re: Reliable Electric pressure washers
    I've used the Greenworks 1700psi electric washer the last 4 years and it's been a champ.
    https://m.lowes.com/pd/Greenworks-17...Washer/3295400
  2. Likes DetailedByPrecision liked this post
  3. #12
    Mar 2018
    Conroe, Texas
    477
    Ryobi units are good, same too for Greenworks, they both use standard fittings, 22M and 14mm-id. Sunjoe units are good buys too but they use the 22M w/15-id but the better units work will with quick release foam cannons. Issue will be GPM and 1.2 and higher is better but Sunjoe overstates their units. Obsessed Garage did a ton of videos on every possible unit. Karcher units work too and often good prices. AR Blue makes decent units and their portable unit is also sold under Standley model at Home Depot and Amazon.
    Top of the line is Kranzle, german made, is over $800 to $1600. If you use it daily then look at nothing less.
    I have used, Greenworks 4-years, Ryobi 1600 portable (gave to my son), Sunjoe 4000 in my garage, and Standley to my daughter. She keeps her F150 clean!
    My opinion only,
    Kirby
    Houston
  4. #13
    Jun 2016
    245
    Look into Northstar. The ones we have are going on 4+ years.
  5. #14
    Dec 2018
    7,164
    Have this from ryobi. Wash once a week and it’s been good
  6. #15
    Dec 2018
    7,164
    3yr warranty and had a brushless motor for duribility.
  7. #16
    Jul 2014
    Toronto
    346
    Quote Originally Posted by Vanquish Auto View Post
    I will check out North star. I am skeptical of German brands because maintenance will be very expensive.
  8. #17
    SELF BANNED
    Jul 2007
    57
    Also have a look at the Ar630tss. Of all the “cheaper” washers Matt tested, the Karcher 1700 performed the best.
    The “northern” washers are simply an industrial motor with a pump bolted on the side. More than likely will outlast almost anything, BUT no auto on/off if that’s important to you.
    Similar to the north star is pressurepro powerwashers.
  9. Thanks ShineMGood thanked for this post
    Likes ShineMGood liked this post
  10. #18
    Super Member Daviddear30's Avatar
    May 2011
    1,302
    I have a sunjoe professional series spx9004
    Had it wall mounted in garage for maybe 7 months.
    I love it. So much better than my 1.2 gpm ryobi was!
    Highly recommend.
    Adjustable pressure and great flow
    Sent from my SM-G965U using Tapatalk
  11. Likes SWETM, Coatingsarecrack liked this post
  12. #19
    Sep 2014
    Fayetteville, GA
    414
    I have AR 2N1 electric. AR makes pumps for a lot of manufacturers so I believe they are reliable. This model is also produced or copied by other companies including GG (just saw it in their latest sales magazine). I like the unit because it has 2050 psi, is mobile and detaches from the cart. There's also a wall mount for it.
  13. #20
    Super Member RaskyR1's Avatar
    Apr 2008
    Shakopee, MN
    3,733
    AR 630TSS. All the power of a Kranzel but a fraction of the price. Need a 20amp breaker though.
    Quote Originally Posted by CieraSL View Post
    http://Raskysautodetailing.com/
  1. PRESSURE WASHERS (electric self priming)
    By 215Detailing in forum Off-Topic
    Last Post: 12-27-2017, 09:53 AM
  2. Reliable pressure washer
    By Bill1234 in forum Auto Detailing 101
    Last Post: 11-20-2012, 06:46 AM
  3. Looking for somewhat strong and reliable pressure washer
    Last Post: 09-21-2012, 09:59 PM
  4. Need to Pick up 1-2 Electric Pressure Washers(Fairly Cheap)
    By ShineTimeDetail in forum Off-Topic
    Last Post: 07-30-2012, 09:30 PM
  5. Pressure Washers
    By ICEMAN in forum Auto Detailing 101
    Last Post: 08-20-2009, 11:06 AM
