Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
    Sep 2017
    Sweden
    3,022
    Re: New pressure washer time. Input/thoughts ?
    Kränzle KWS700TS
    Specifications
    PSI: 2400
    GPM: 3.3
    Electrical Requirements: 220V, 15A, Single Phase
    Weight: 175 lbs.
    This is one of 220V OG has. The benefit with 220v-240v is the higher psi+gpm you can get with higher voltage.
    The biggest one on 220-240v we can get in Sweden is Kränzle K2160 TS. Workload psi is 450-2000psi and 3.0gpm. And it is the portable ones like the K1122 TST looks wise. I don't know if it could come with the electric outlet that fits for you. And the kränzle PW is a buy once. You can get spare parts on everything to it. Sure it's pricey but with a care of it you have a PW for life. And IMO the higher specs you have the budget to get the more use of it you get. You can hold the nozzle tip farther away from the vehical with a more higher specs PW. Then the kränzle PW you can adjust both the psi and the gpm to suit the work you are doing. I would also get one with the lower 1400rpm electric motor on it. That lower the noise level and the wear on the water pump. If you go up to Kärcher Pro PW you have a higher quality and the standard m22 fittings. That could be worth to look into also. I would call either OG or Kränzle USA and talk with them on which PW unit would suit your needs.
    Jun 2013
    Montreal, Quebec
    3,996
    Yeah I have a ryobi from HD and it’s 4.5 stars on their site with 841 reviews. It’s instant on/off. Uses a brushless motor. 2300 psi. It’s low gsm but great for car washing.
    Hum... stats for this unit seems very bad for car washing...
    You want pressure bellow 2000 PSI so you don't damage the paint, and you want the most flow you can get and 1.2 GPM is pretty much the lowest you can find in a pressure washer.
    This unit may be good, but it's not what I would recommend for washing cars.
  3. #13
    SELF BANNED
    Jul 2007
    57
    I already have all the other components, gun, lance, etc. I’m now basically pump shopping.
    I notice Matt doesn’t have hot water. Would it not be nice to wash with hot water?
    The kranzles I’ve listed are only cold. The AR 630 can do hot water.
    I’m really liking the north star 240 washer. Nice flow, good price, BUT it doesn’t appear to have auto start/stop. Too bad cause it’d plug right into my construction heater outlet
  4. #14
    Jun 2016
    245
    I really wish Northstar would do the auto shut off. I have two of them now and both are tanks. I’ve thought about adding the AR630 to have a hot water option.
    Quote Originally Posted by bean438 View Post
  5. #15
    Sep 2017
    Sweden
    3,022
    The standard PW are mostly rated to max 140F. And that is what the kränzle K2160 TS I looked at too. The warmer water makes a big difference in the cleaning ability. Also foam benefits with warm water and prewash products gets more effective too.
  6. #16
    Mar 2017
    Southeastern PA
    2,480
    Bsoares, do you own a kranzle?
    Unfortunately I don’t. Can’t afford that much for a pressure washer used only for 2 personal vehicles.
    Bruno Soares
  7. #17
    Dec 2018
    7,151
    Quote Originally Posted by Calendyr View Post
    Actually the opposite of this ^^ in my experience(research I did and experience with owning using this PW since beginning of summer). I’ve used +2000 psi PW’s forever. Never damaged paint. These estimates from manufactures never accurate and that’s why I look for higher rating. (kranzel above has 2.4 and seems to work fine). And 1.2 gpm plenty to rinse off a car/truck. More would be better for your bigger flat surfaces (fences, decks, driveway) The OP was looking instant on/off which if I believe right is machine runs when pulling gun and shuts off when not which this does. It also uses a brushless motor which is more durable than the ones with brushes. Just my 2 cents on a more affordable options. If I was spending over $600 I’d buck up and get a kranzel. Last but not least won’t find to many PW’s with 800+ reviews at 4.5 stars from a reputable place.
  8. Likes fly07sti liked this post
  9. #18
    SELF BANNED
    Jul 2007
    57
    Auto on off is a nice feature. Would it be hard to add this? MTM Hydro sells pressure switches. Surely if a 200 dollar model from Home Depot can do it, it should be able to be added to a North Star or equivalent ?
  10. #19
    Dec 2018
    7,151
    Prolly void warranty. Go with the kranzel
  11. #20
    Nov 2014
    149
    B5visser, the 360tss is 18 amps, requiring a 20 circuit. I’m surprised your up and running. Have you used a foam cannon at all with the AR? Is your 15 a dedicated circuit?
    I'm not an electrician, but I know the GFCI is 15A, however, the breaker in the box is 20A. Never "tripped" either of them.
    And I do run a cannon- I have a couple cheap amazon specials with 1.1mm orfices. They generate sufficient foam for me, albeit, less than a gas pressure washer.
    "Hot" water is nice. I live in Michigan where the low last night was actually -20. Even feeding the washer with ~120 degree (hot water heater) water dramatically speeds up the time it takes to wash off snow and salt buildup, and is a nice feature IMO.
    I too was between the AR and the kranzle. No experience using the Kranzle, but I'm pleased with the AR.
    Brandon Visser | 269-569-1900 | b5visser@live.com
    Owner/Appearance Specialist | @domainappearance
  1. Replies: 12
    Last Post: 12-13-2017, 08:25 AM
  2. another pressure washer is dead, time for an upgrade.....
    By Matt@Revive in forum Auto Detailing Tools and Accessories
    Last Post: 01-08-2017, 01:17 PM
  3. Logo design thoughts and input
    By Evan.J in forum How to make money detailing cars
    Last Post: 08-10-2013, 01:34 PM
  4. Getting second thoughts on this pressure washer!
    By HardLineDetail in forum Auto Detailing 101
    Last Post: 05-30-2013, 01:01 PM
  5. Replies: 6
    Last Post: 10-28-2011, 03:11 PM
