» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Sep 2017
    Sweden
    1,624
    Re: what does 9H mean in relation to coating
    Quote Originally Posted by BSoares View Post
    Refer to pencil hardness test. The Pencil Hardness Test
    Wonders what hardness different clearcoats has if doing the pencil hardness test on them.
    Senior Member UncleDavy's Avatar
    Aug 2017
    Taunton, MA
    622
    NOTHING beats the marketing of top coat F11, period! Just this morning I put on Peppa Pig for my three-year-old daughter and an advertisement for that damn company came upwhat does 9H mean in relation to coating
    They do know how to market that product and I was intrigued at first. Then I took a closer look at this picture. They say that it is the surface of steel magnified thousands of times under an electron microscope. I didn't know that electron microscopes had blue sky and clouds.
  3. #13
    Senior Member Oz_TCH's Avatar
    Jul 2012
    Northern Virginia
    148
    I'm no expert but you know ? Holiday Inn ?
    Got this from the interweb....
    The Mohs' hardness scale was developed in 1822 by Frederich Mohs.
    This scale is a chart of relative hardness of the various minerals (1 - softest to 10 - hardest).” - as defined by Mineralogical Society of America.
    The common softest mineral out there would be talc (baby powder rates as a 1 on the Moh scale) and the hardest substance in nature is a diamond (rated as a 10 on the Moh scale). The next closest object in hardness to a diamond coming in at a 9, would be ruby and tungsten carbide (commonly used in drill bits). Synthetic diamonds or cubic zirconia, comes in at 8.
    Most car owners are also generally concerned over the possible damage from vandalism including:
    a) Coins (3.5 on the Moh scale)
    b) Knife blades (5.5 on the Moh scale)
    c) Fingernails (2.5 on the Moh scale)
    Some coating specialists claim that they have a coating with a hardness of 9. If this were true, a synthetic diamond (cubic zirconia at 8) would not be able to scratch such a coating! Only other elements such as ruby, tungsten carbide and real diamonds would be able to scratch these coatings claiming a hardness of 9.
    "A hardness claim of 9 on a glass/quartz/ceramic/crystal coating is physically impossible."
    Coatings are formulated to be tough enough to withstand most of the common elements that car owners have to face with daily driving. Si02 coating will cover the bulk of your protective needs. It would be highly unlikely someone would come out to intentionally vandalise a car with a real diamond ring, real ruby bracelet or tungsten carbide drill!
    Another common test of hardness for coatings is the infamous pencil hardness test or the Wolff-Wilborn test. This test which is carried out in a laboratory setting where pencils of various hardness are used to intentionally scratch a surface or coating to see how well it resists scratching. Usually with a maximum pressure of about 2 lbs/f using different pencils, the hardness rating (H) is derived based on the pencil used. However, such tests do not represent real world conditions. Even poor car washing practices such as using a damaged rag can potentially scratch a coating on a car.
  4. Likes BSoares, rlmccarty2000 liked this post
  5. #14
    Senior Member Eldorado2k's Avatar
    Nov 2015
    Los Angeles, California
    9,254
    It means squat. Meaning don’t buy into the marketing of coating hardness. They can still swirl and scratch. They do help with wash induced marring that may occur.
    If it’s not swirls, what exactly is “wash induced marring”?
  6. #15
    Senior Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,050
    IMO:
    Marketing moguls’ mostly meaningless meanderings.
    Thats a 5M quote right there!!! Better than 3M or even 4M!!! lol
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
  7. #16
    Senior Member KBsToy's Avatar
    Jul 2011
    SW...Pa
    1,317
    Must be reading about Adams new product another spray ceramic.
  8. #17
    Senior Member Desertnate's Avatar
    Aug 2013
    St Louis metro (Illinois)
    3,537
    You can get swirls from lots of different sources such as washing, drying, bird dropping removal, and a big one in my area is snow/ice removal. Even with the softest snow blade or brush you'll probably get light swirl marks.
    I define wash induced marring as the *very* light marks (swirls) that occasionaly show up from the washing/drying proces for someone taking the right precautions. The kind you only see when you look at the paint under certain conditions and certain angles. We're not talking about the marks that result from washing with a red shop rag and drying with an old terry cloth towel which cloud the paint and make for great 50/50 pictures here at autogeek. Personally I've noticed my coated vehicles stay marring free far longer with a coating than when I used a sealant. With a sealant, I'd start seeing the light marks at the six month point, maybe sooner if the winter was bad and I had to clean off my car more often. With a coating, I can easily go a year. The difference for me was quite noticable on my wife's Toyota which marrs if you breath on it wrong.
    Save the Manuals!!
  9. Likes The Guz, SWETM liked this post
  10. #18
    Member Sleper's Avatar
    Mar 2006
    39
    Quote Originally Posted by KBsToy View Post
    Has anyone tried it? Ease of use and durability?
  11. #19
    Nov 2015
    9,254
    Great... I just made a thread asking about this. So basically it just means swirls?what does 9H mean in relation to coating
    So why say coatings don’t resist swirls... But they resist minor swirls? That doesn’t make any sense.
    IMO marring means marks, not swirls. And I’ve never seen marks get left behind after washing a car.
  12. #20
    Senior Member Klasse Act's Avatar
    Feb 2012
    Elk Grove Village Illinois, USA
    15,542
    Quote Originally Posted by Sleper View Post
    It just came out, LOLwhat does 9H mean in relation to coating
    2013 Abarth coated w/TAC system Power Plus 2x's 6-2-18
  1. Replies: 38
    Last Post: 10-09-2017, 07:55 AM
  2. Replies: 6
    Last Post: 08-21-2017, 09:27 AM
  3. Replies: 11
    Last Post: 08-09-2016, 09:29 AM
  4. Replies: 9
    Last Post: 04-19-2016, 12:35 PM
  5. Replies: 7
    Last Post: 11-03-2013, 06:34 AM
Members who have read this thread: 92
» January 2019
3031 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
