Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Aug 2018
    Re: Rust chips and Dr Color Chip, light driftwood satin glow Paint Code PFA
    Quote Originally Posted by itsgn View Post
    You need to sand _after_ you've applied the touch up paint to the cleaned surface. (obviously after you've cleaned it, and removed all rust)
    Iv always thought "cleaning" rust away required sanding. Is Iron X and 3000 grit enough to "clean" and neutralize the rust before primer and paint?
    Man do I wish my truck was white!
    Quote Originally Posted by davidc View Post
    Wow, that's a lot of chips. Kind of like pepper sprayed. Some body must have been driving behind a gravel truck.
    Dave
    Yeah, and I paid a rust free price only to learn it needs a paint job!
  2. #22
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    Too bad Dr Colorchip didn’t respond. I’ve used their system on three cars and have always been happy with the results. My chips were not rusted though. There used to be a chemical pen that would change rust to a paintable surface. I haven’t looked for one in a long time. The Dr Colorchip is made for multiple chips like you have. They have a squeegee method that would be ideal. I don’t have the patience to do that many chips individually and make it look right. Try calling Dr Colorchip.
  3. #23
    Nov 2017
    245
    Quote Originally Posted by rerod View Post
    That's not required, but might be an effective and cheap way to remove it on a larger surface which is easily accessible and can be or even possibly should be flattened anyway. However, that's absolutely not the case with rock chips, which are tiny spots and are craters in the surrounding paint, which you should try to leave as much untouched as possible. Otherwise you will just make the chip larger, which in turn will need more paint to get filled, more sanding to get perfectly flattened and blended, and if there will be any difference between the original and the touch up paint (which always will be in the case of metallic paints, even if the color match is perfect, which again, won't be if your paint is older than a few years) will make the corrected area easier to spot.
    So, with rock chips the best solution is to use something that dissolves rust, but doesn't touch neither paint, nor the in-tact metal below the rust. Iron oxide removers like Iron X do exactly that. You might want to use a qtip to agitate the remover in the chip craters though, otherwise you'll need a lot of repeat applications until it can remove all the rust on its own.
    Iron X does not "neutralize" the rust, but dissolves it and carries it away. Or more precisely: let's a wipe or a rinse with water carry it away. Sandpaper is not needed for rust removal from rock chips, and is actually in my opinion the worst way to remove them, for the reasons explained above.
  4. #24
    Aug 2018
    Quote Originally Posted by rlmccarty2000 View Post
    Yeah, I should have spent more time on Dr Colorchip and didn't know about their squeegee method. Its always 20/20 after the fact tho
    Boy, I'm glad I didn't sand more than one of the bigger chips..
    This thread is a great how to, on how not to rather
  1. How to fix this rust spot/paint chip?
    By TheMidnightNarwhal in forum Off-Topic
    Last Post: 04-11-2018, 08:53 PM
  2. Dr.color chip paint match
    By asap2stacks in forum Auto Detailing 101
    Last Post: 09-02-2017, 12:33 PM
  3. What to Thin Dr Color Chip Paint with?
    By MarkD51 in forum Ask your detailing questions!
    Last Post: 03-09-2017, 04:53 PM
  4. Repairing chips in paint with rust
    By Stephan@FamouslyHot in forum Auto Detailing 101
    Last Post: 09-16-2014, 08:24 PM
  5. paint chips and rust
    By jhnybgood47 in forum Auto Detailing 101
    Last Post: 10-26-2012, 08:12 PM
