Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Aug 2018
    How to correct these paint defects
    Hello,
    I have a 2013 Black Honda pilot with the following paint defects. Not sure if they are etchings from bird droppings, etc. I tried compounding and polishing with no success. Is the next step to try and wet sand them out, then follow with M105 and M205, and then a sealant and wax? Any input is appreciated.
    Thank you
    Attached Thumbnails Attached Thumbnails How to correct these paint defects-paint1-jpg   How to correct these paint defects-paint2-jpg
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    Re: How to correct these paint defects
    Yes
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    Aug 2018
    What grit sandpaper should I start with?
    Sep 2018
    282
    Bird poo etching mate.
    Google the hairdryer technique, doesn’t always work but it’s worth a try before permanently removing levels of clear coat.
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by gdlabo View Post
    You won't need much. I come across marks like that on cars I do and use 3000 grit. Doesn't take much. Better to work slow and refine where needed, especially if you're not using a Paint Thickness Gauge.
    2023
  6. Likes SWETM, gregg brannigan liked this post
  7. #6
    Aug 2010
    New Jersey
    15,158
    Quote Originally Posted by TTQ B4U View Post
    I can't say I agree with that. If you're talking about a shadow mark, then maybe, but that/those (I think those are two different pictures of the same spot, but maybe two different similar spots) are crinkly/crazed looking which IMO are unlikely to be improved much by sanding, and could get worse.
    Now that I agree with. OP, please, please, PLEASE be very careful with this if you opt to sand, especially if you've never done anything like that. There are many, many sad threads here which start with "I tried to sand this chip/scratch/etch and now the whole area is a different color...what happened?" They also frequently have content like "they didn't have any 3000 grit so I got 1000 grit instead" or "it started looking a little better so I just kept going".
    Car paint is really thin, it looks to me like it's mechanically compromised from the chemical etch, you can get in a lot of trouble in a hurry with sanding, please be careful.
  8. Likes rlmccarty2000 liked this post
  9. #7
    Aug 2018
    I have both 1500 and 3000 grit right now, but I definitely do not want to make things worse. I will google the hair dryer technique. I may also try some M105 as well as last time I tried Griots correcting cream(not their fast correcting cream). I will also try to read up on wet sanding paint.
    Thank you
  10. #8
    Super Member rlmccarty2000's Avatar
    Dec 2013
    Fitzgerald, GA
    2,002
    I going to go with Setec, it looks like paint bubbling and sanding will possibly make it look worse. There is no real solution except a repaint. But the damage it already done, sanding will only take it down to base then primer.
  11. Likes dlc95 liked this post
  12. #9
    Aug 2018
    Is the consensus to try sanding them out, or is repainting the only option?
  13. #10
    Aug 2010
    New Jersey
    15,158
    Can you get some closer-up pictures? How many spots are there, and where are they on the car?
    If you can't live with them the way they are, and are considering a repaint, it certainly can't hurt to try to sand them first, if it goes bad, just get the repaint. But let us look at some better pictures first.
  14. Likes dlc95 liked this post
  1. Replies: 7
    Last Post: 10-12-2020, 10:26 AM
  2. help serious paint defects
    By pagaz in forum Auto Detailing 101
    Last Post: 11-09-2013, 02:28 PM
  3. Need help with some paint defects
    By daggerNC in forum Ask your detailing questions!
    Last Post: 02-28-2013, 01:16 PM
  4. Paint Defects
    By Always Learning in forum Auto Detailing 101
    Last Post: 12-24-2012, 02:15 PM
  5. How to correct these defects?
    By rjgervacio in forum Ask your detailing questions!
    Last Post: 05-09-2011, 01:30 PM
