Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Regular Member Beerwulf76's Avatar
    Sep 2011
    143
    Dr. Beasley's Formula 1201 Paint Coating tips/suggestions
    Hello there, Autogeek family. I just purchased some
    I would like some tips and/or suggestions on how to apply the coating. It comes bundled with Dr. Beasley's AdvanceCoat: Gloss.
    I am wondering if advancecoat can be applied right after Formula 1201, being that 1201 claims no required "extended" curing time.
    I will be working on a champagne colored 2014 Toyota Sienna. Paint is in very good shape with just a need of some deep cleaning and light/finishing polish for minor swirls.
    I plan to wash, clay then polish. 1201 is to be applied to wet paint so rather than hosing vehicle down I figured it'd be better to spray individual panels down with a water spray bottle to apply the 1201. Any suggestions or input is appreciated
    Sep 2011
    143
    Re: Dr. Beasley's Formula 1201 Paint Coating tips/suggestions
    A watched pot never does boil .
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    There are not many users of Dr. Beasley's so that is probably the lack of responses. I myself am not familiar with using their products.
    Sep 2011
    143
    I have no doubt that is the case. I wonder why that is, seems like a fine line of products. I guess they get lost in the shuffle amongst more populars offerings.
    That being so, some theories on how to approach application would be helpful. I know they will comewith fairly detailed instructions. However there's directions and there's directions + method and technique.
    Anyhow thank you Guz for taking the time to reply.
    Sep 2017
    Sweden
    3,022
    Read the description of this. And it's seems important to use destilled water as a last rinse before coating it. So the spray bottle and destilled water in it before applying it would be a thing to think of. It says to do a panel at the time. But I would test out different sizes of areas when I start. To see how it behaves in your environment. And since you apply it wet I would have alot of dry mf towels at hand and maybe with different nap on them. To see which works best for you. Seems to be a straight forward application.
    Please if you will do a review and write up and pictures from your application of it would be nice.
    /Tony
    Nov 2009
    Pasadena, CA
    12,615
    Tried this stuff and was not impressed at all.
    '03 Corvette Z06
    Sep 2011
    143
    What aspect of the product were you not pleased with or did not meet your expectations ?
    Sep 2011
    143
    So I got to use my Formula 1201 today!
    Applied it to a 2015 Honda Odyssey (dark blue).
    The paint was fairly clean with some need for minor correction. Began a liquid clay product, which does a very thorough job of deep cleaning the paint. After this step flooding the surface reveals a completely hydrophilic effect, water does not run off at all, very telling.
    Followed this step with Meguiar's Super Soap.
    After this the surface was clayed an OTC brand clay, to remove any remaining contamination.
    Followed this step with Meguiar's #2 Fine Cut cleaner applied to a Lake County orange foam pad on a dual action polisher.
    Then another wash with Super Soap to remove polishing oils/residue. The surface was rinsed purified water and kept wet via filtered water in a sprayer bottle.
    Now on to the wet application! This is where things get tricky. While the product does turn the water into an opaque gel like substance you do have to kind of trust the coating has been completely and thoroughly applied to the area which you are working on.
    Another challenge is knowing you are using the correct amount of product and not too much nor too little.
    Water a tends to run and drip down the surface as it is being applied, hinting at hydrophobic properties taken on by the finish.
    Removal with a microfiber towel is a breeze, leaving a smooth semi slick feel somewhat reminiscent to using a wax as you dry product.
    While the end result seemed to reveal a brighter more reflective finish, the effect is subtle, no real wow factor.
    My foremost goal with the application of this coating was to provide the finish with protection, mainly against bug splatter on the forward facing panels of the vehicle such as the hood, bumper/grill, two front fenders, two front pillars and side view mirrors. Due to time and other contraints, only those surfaces were treated with the said coating.
    While aesthetics were not a primary concern I was disappointed on the level of paint correction I was able to achieve with the Meg's #2. However, that was likely due to my lack of focus on that aspect, as my main concern was to provide a bare clean "slate" for the 1201 to bond to.
    Now, this vehicle is scheduled to leave town tommorow, so I'll have to wait another week at least before the water behavior and repellency/release properties of the coating can be assessed .
    I shall report back with my findings as soon as it is available.
    Super Member Misterpaul's Avatar
    Sep 2009
    Plainfield, Il
    1,369
    For grins and giggles I applied Dr. Beasley’s 1201 Paint Coating to the boot lid of my SS. This morning a passing shower landed on my corn pollen & dust coated SS. Here’s a pic of the water beading:
    Meh!
    Here’s the dried water spots three hours later:
    Tonight after I get home from bass fishing I’ll Rinseless Wash the SS and see how the coating performed. Not impressed with the beading so far or the Advanced Coat: Gloss which made a streaky mess
    2017 Phantom Black Metallic Chevy SS, automatic, skylight, plus unused wheel in the boot.
  10. #10
    Nov 2015
    Los Angeles, California
    13,765
    Wow what a sham... Does any Beasley product work even slightly? I had the same results with the 1 product of theirs that I purchased. That’s worthy of a refund.
  1. Dr. Beasley's Formula 1201 Paint Coating
    Last Post: 10-17-2020, 09:38 AM
  2. DR Beasley's 1201 on new car paint?
    By keninfl in forum Ask your detailing questions!
    Last Post: 10-09-2020, 01:29 PM
  3. Dr. Beasley 1201
    By waterman in forum Auto Detailing 101
    Last Post: 09-26-2020, 06:57 PM
  4. Replies: 10
    Last Post: 09-02-2020, 12:31 PM
  5. Dr beasley 1201
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 02-11-2019, 09:18 AM
