Re: HD Speed Removal...
Decided to give HD Speed a fourth try and take some of Mike Phillips advise. Decontaminated the rear the the 2007 CRV and ran my clay mitt over the panel.
Using my PC which is set up for 3" pads added some Speed in a thin circle around my LC green pad. Worked a smaller area with a little faster arm speed doing the usual 4 passes. I then added about 4 pea sized drops there after to the pad and finished up the panel working about a 16x16 area each time. Given the glass I had a smaller panel to work with any way. So after I finished I gave it a few minutes and proceeded to wipe off. No issues with removal, wiped off easily as it should have.
Having better results this time certainly was a plus but given the prior issues I had isn't going to make it my go to. I do have some Mckee's 360 coming in later today and will give it a try on the left over door panels. Will be interesting to see the results side by side to the Speed I have on the front door panels.
Also wondering if the disaster I had with Speed on the hood had anything to do with the product I had on the hood prior. About a month ago I had applied DG 501/111 to the roof and hood to test durability. Didn't like the look so I wanted to remove it from the hood.
Cannot speak to the potentially contributing factor of the prior product, but I have had experience with both Speed and 360. I think what you will find is that the Speed will give you more gloss and slickness, but the 360 will cut a little better and the protection it provides will last much longer. The only negative I've found with 360 is that it permanently stained the pads I was using, so they've now been relegated to '360 pads only'.
By AllenK in forum Auto Detailing 101
Last Post: 07-29-2018, 12:25 PM
Last Post: 07-22-2018, 07:00 PM
By spa in forum Auto Detailing 101
Last Post: 07-23-2017, 12:41 PM
By anson89 in forum Show N' Shine
Last Post: 06-17-2016, 10:31 AM
By A.P.A.D. in forum Auto Detailing 101
Last Post: 12-09-2011, 12:46 PM
