» Detailing Classes
Results 11 to 20 of 33
    Senior Member kevincwelch's Avatar
    May 2013
    Oak Park, IL (Chicagoland)
    2,680
    Re: Gyeon vs. GTechnic which do you prefer.
    Nice panel test, Ancient1!
    Looks like Syncro really beads up -- and that's no so good in my mind. Looks like it is the dirtiest panel -- or any panel with Skin on it. But, it clearly acts differently on your water and drying demo.
    Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
    2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
    Member oc412's Avatar
    Feb 2016
    SoCal
    44
    If you are looking into interior check out the Gyeon Fabric Coat. Its expensive but works amazing. I have used it on a couple clients vehicles and have had amazing results. Check out the hashtag on instagram for some good videos of it working. I think I paid like almost $60 for a bottle of it. I am pretty sure that it is ceramic based, but not positive. I like the Gtechniq C2v3 liquid crystal as a really good spray sealant. I use it and the Gyeon Pure as a spray sealant. I have applied the MOHS to a few vehicles and my 2017 F-150 and absolutely love it. It is fairly easy to apply but I learned its a must have proper lighting while applying it as with any coating. I use Gyeon Prep all of the time when I polish before applying a wax or sealant. I love the smell of it and it works very good. Gyeon also has really good soaps for foam guns.
  3. #13
    Senior Member Eldorado2k's Avatar
    Nov 2015
    Los Angeles, California
    8,976
    Quote Originally Posted by Ancient1 View Post
    If yoy want to see how they react to water here is a edited clip Idid at the 1st wash and was the reason I used syncro on my car, syncro is skin on mohs.
    Why does it look like your foam cannon is filled with skim milk instead of car shampoo? Is it supposed to be like that? If so, thatís a bit mind boggling. Maybe itís just me, but Iíd be frustrated to no end if my foam cannon worked like that.
    I canít get over the foam cannon part. Lol. What in the world kind of soap is in that bottle?
  4. #14
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    5,639
    Quote Originally Posted by Lamented View Post
    Interested in the interior products. As far as coatings go. I’m thinking my best bet would be Can Coat. I would love to try a better coating but I have no shade to apply it.
    Interior wise Gyeon Leather Coat, Leather Shield and Preserve are all great products. I've used all three of them.
    Gyeon CanCoat is a good place to start. Great product to work with. Good performance from it.
    Gyeon Syncro is easy to use and has been performing well in the 7 months it has been on my dad's car. Gyeon MOHS goes on and off easily. As does the topper skin.
    Gyeon Trim and Rim are also easy to use and have been performing well.
    Gyeon Tire Coating is a good tire product. Leaves a matte finish as it is not the glossiest tire dressing.
    Gyeon Bathe is nice but it is not cost effective. Bathe Essence is the latest shampoo and I am not overwhelmed by it. Seems to watered down and I have to use the same dilution ratio as Bathe to get decent performance from it.
    From GTechniq C6 Matte Dash is nice.
    Gtechniq C4 trim coating is easy to use. Similar performance to Gyeon Trim.
    GTechniq C5 wheel armour is easy to use like Gyeon Rim. Gyeon Rim is more hydrophobic. Some choose to use Exo on top of C5 to add more hydrophobic properties.
    Crystal Serum Light is easy to use. Goes on and off easy. Similar to Gyeon Mohs. I find CSL to be slightly more hydrophobic.
    Exo is not as user friendly as CSL. I speak to V3 and not V4 that just came out. It's hydrophobic properties are pretty nice.
    GTechniq Panel wipe is probably the strongest of the panel wipes on the markets.
    I hope this helps.
  5. Likes SWETM liked this post
  6. #15
    Sep 2017
    Sweden
    1,496
    I personally like working with the Gtech a little more than the Gyeon. But the slickness of the Syncro kit is hard to top. This spring I did my Car with Syncro and leather shield on my leather. This weekend I did a F150 that my son just got and it pretty much is all Gtechnic. Coated with CSL/ExoV4 glass with G1 on the windshield and G5 on the side glass I1 on the carpet T1 on the tires.
    With leftover products I also did my wagon with CSL on the paint topped with Skin the vinyl got EXOV3 just tyo see how skin and CSL work as a pair which if could be purchased separately would be my coating of choice.
    Earlier this spring I did some testing of toppers on coatings and used CSL and a base coat on the drivers side and trunk lid with Mohs on the passenger side top. Here are a couple pictures I took at a little over 4 months of how clean each stayed. To me as far as being hydrophobic The skin is noticeable better even tho I haven't seen how EXOv4 does since I just used it last Sunday.
    Wow what a difference in the self cleaning ability on your test panels. The mohs+booster sections looks great in that expect. And the Syncro sure has some great water beading. But the sheeting properties don't seems to be as effective. Maybe you get away with it if you drive the car regualary so the beads rolls of. The self cleaning ability I see works best on LSP with a high sheeting ability.
    To the OP I think you will be fine with either of gtechnic and Gyeon. Maybe Gyeon has a little bigger line of products. But with the chemicals you have them on par with each other.
  7. #16
    Senior Member Ancient1's Avatar
    Sep 2015
    Sun Prairie Wisconsin
    212
    I am pretty sure for that it had about 3oz of Gyeon Foam (my normal mix) and 6+ of Hyper-wash by looking at the color to try to get more foam. It was the first try with the PF22. The problems with having very hard water. My other canon does better but still leaves a lot of room for improvement. From what I have tried it seems the Gyeon and Angelwax foam.s do the best .
    Here are the ones I have tried so far at different strengths.
  8. #17
    Sep 2017
    Sweden
    1,496
    What is your specs on the PW?
    With only the chemicals and no dilution and the mix setting on the foamcannon to max chemical. You would get shaving cream thick foam. Since I asks about the specs on the PW. Is you might need a smaller orifice in the foamcannon. To get you a thicker foam.
  9. Likes PurpleTowel liked this post
  10. #18
    Sep 2015
    212
    It is rated 3100psi and 2.8gpm But my gauge it is around 2900 and drops to about 2500psi when rinsing with the white tip.
    Here is a short clip showing the pressure.
    https://photos.smugmug.com/PW/i-T3Ch...20/PW-1920.mp4
    There was dilution that was the aprox amount added to about 24oz of water.
  11. Likes SWETM liked this post
  12. #19
    Sep 2017
    Sweden
    1,496
    Then the orifice is not the problem lol. It's about the specs I have too and I have gone up from the original orifice 1.25mm to 1.30mm orifice. But with your hard water I would not do that and keep the 1.25mm orifice on. Have you tested with either use some warm water or destilled water to the foamcannon bottle. With 3oz and about 24oz of is my useally mix. And with the setting on max chemical output from the foamcannon I get a nice foam that is not to thick or to runny. You can also have almost 1:1 dilution in the foamcannon bottle and play around with the chemical mix setting. The hard water is a PIA to get it foam up.
  13. #20
    Nov 2015
    8,976
    What about a product like the new Blackfire Foam Booster? Wouldnít that solve the problem?
  14. Likes SWETM liked this post
  1. Dlux vs Gtechnic C4
    By dchristo in forum Auto Detailing 101
    Last Post: 03-23-2015, 03:52 PM
  2. Replies: 14
    Last Post: 07-31-2014, 06:32 AM
  3. Recommended towel for removing Gtechnic C1
    By ralphwiens in forum Auto Detailing 101
    Last Post: 04-03-2013, 04:19 PM
  4. Gtechnic P1
    By royale in forum Product Reviews
    Last Post: 09-19-2012, 06:32 PM
  5. Gtechnic Crystal Lacquer
    By LAMF in forum New Car Care Products
    Last Post: 09-03-2012, 06:44 AM
Members who have read this thread: 132
» December 2018
252627282930 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31 12345
