Exterior Trim Sealants
I noticed that Wolfgang makes an exterior trim sealant. Does anyone else make a comparable product? When I search for "Exterior trim sealant," all I get is the Wolfgang product.
Re: Exterior Trim Sealants
It's my favorite. Others may like something else, but I really like it.
I'm in the market for something like this too. Just got a vehicle with lots of textured black plastic on the exterior. It's all still in good condition, so now's the time to protect it. I've always known about WETS, but are there any other options?
CarPro DLUX
McKee’s Plastic Trim Restorer. It advertises lasting months, not weeks. Directions don’t specify if it can be used on rubber, but I’m guessing it can.
Meg’s Ultimate Black Plastic Restorer. It claims weeks. Can be used on rubber.
Duragloss makes a good one. Very similar to WETS.
Is the old Blackfire Total Trim & Tire Sealant any good?
Originally Posted by
AZpolisher15
What product is that ?
carlg
CarPro PERL:
Gives a very deep black, but doesn't last long. Gets streaky as rain washes it away, and will be washed away fully after a few rainy days. Because of that I suggest you only apply it to areas that are not exposed directly to rain - like engine bay, car interior.
Meguiar's Ultimate Black:
Give a less deep black, but lasts a lot longer even on surfaces that are directly exposed to rain. It still gets washed away by rain, but it takes a lot longer, and some of the darkening effect still seems to linger around even after months.
CarPro DLUX or Gtechniq C4:
These are not actually sealants, but semi-permanent trim coatings. They last a LOT longer than any of the above coatings (up to a year or so), but they're very expensive and very finicky to application. You need thorough preparation or you will get uneven, streaky results, which will now be virtually permanent and hard (if not impossible) to correct (well, at least up to the year mark). Also, they're not as dark as the best sealants, but still give you decent results, which lasts.
There are also trim restorers which contain (black) color pigments / dye. They're essentially like paint. They give you the best results in terms of deepness of black and color restoration, but they're also relatively expensive, and with time might fade unevenly, and depending on the dye used, even discolor (turn for ex. from deep black to black with a purplish tint).
