Results 1 to 6 of 6
    Jun 2017
    Meguiars Ultimate Polish ok before ceramic coating??
    Hi,
    I'm not sure if the ultimate polish can be used before ceramic coating a vehicle. I'm asking because in the description are rich polishing oils mentioned...
    I plan to use Gyeon Prep and then Q2 pure. Will the prep be enough to take care of the oils, or should I use a different polish?
    Thanks for any input.
    Nov 2009
    Pasadena, CA
    12,615
    Re: Meguiars Ultimate Polish ok before ceramic coating??
    UP contains a good amount of polishing oils, so make sure you do a thorough wipe down with Gyeon Prep.
    Sent from my LG-H932 using Autogeekonline mobile app
    '03 Corvette Z06
  3. Likes TTQ B4U liked this post
  4. #3
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by Swisstyphoon View Post
    Hi,
    Yes. I do it all the time. Just give it a very liberal spray of prep, then wipe.
    Sent from my Galaxy Note 8 using Tapatalk
    2023
  5. #4
    Sep 2017
    Sweden
    3,022
    I would get an other polish cause of the rich polishing oils and some fillers I think too. Gyeon Polish or even better if you think that UP would get your paint as where you wants it is Gyeon Primer. With Gyeon Primer you get the polishing part of the Gyeon Polish with a little less amount of abrasives in it. The biggest benefit with Primer is the sio2 base it leaves behind that makes it a perfect finish to apply your coating on.
    GYEON Q2 Primer 120 ml.
    GYEON Q2M Polish
  6. Likes TTQ B4U, VitreousHumor, BudgetPlan1 liked this post
  7. #5
    Jun 2017
    Thanks for all the replies Guys.
  8. #6
    Aug 2013
    St Louis metro (Illinois)
    5,809
    Quote Originally Posted by TTQ B4U View Post
    Same here. Until I ran out, it was my go-to polish for vehicles with soft paint. It is an oily polish as already mentioned, so I would always do a heavy/careful wipe-down to make sure the surface was clean.
  1. Review: Meguiars Ultimate Black Tire Coating
    By Bryan@Autogeek in forum Product Reviews
    Last Post: 01-21-2014, 12:51 AM
  2. Meguiars Ultimate Polish
    By Coopers ST in forum Products Guides
    Last Post: 11-26-2013, 11:32 PM
  3. can i use meguiars ultimate polish in sun ?
    By nycbluelancer in forum Wet-Sanding, Cutting & Buffing
    Last Post: 06-11-2013, 08:24 AM
  4. Best polish after using Meguiars Ultimate Compound?
    By jcedorjr in forum Auto Detailing 101
    Last Post: 06-07-2012, 11:52 AM
  5. Meguiars Ultimate Polish - cut level??
    By Detail_Dude in forum Auto Detailing 101
    Last Post: 02-28-2012, 03:18 PM
