Page 6 of 6 FirstFirst 123456
Results 51 to 56 of 56
  1. #51
    Senior Member h8dirtycars's Avatar
    Feb 2017
    152
    Re: Topping AIO’s with Sealant - Basic test
    That said, I'm not a fan of coatings. If they were truly maintenance-free afterward, maybe. But having to maintain the initially $$ product with more $$ products does not jibe with me. JMHO....
    I'm pretty new at this, but I kinda agree, even though I've purchased CQUK 3.0 (didn't use yet) and Reload.
    Just curious, what do you use then, just wax I'm assuming. I've used the Collinite 845 and like it pretty well. Use Ech2o and the Ech2o/Reload mixture on top of that which worked pretty well for me.
  2. #52
    In time out
    Apr 2016
    852
    Do the sealant seal in the filling the AIO has till it's done?
    And do you get the same longevity from the topped sealant as with a sealant applyied on bare paint?
    Do you have any done cars coming back and about how long does it takes or do you have a regualar maintance schedule with customer?
    Lets say that you use an AIO and compare it to the polish of the same brand. You use the same pads. Does the polish abrade so much more clearcoat that in the longrun you came to the point where it's not longer safe to polish/remove more clearcoat? Cause the d166 seems to have a good cut to be an AIO.
    And this is just for me to get experience from you. And not trying to convince you to change your mind.
    Many of my customers bring me their cars every 6 months and depending on budget I'll almost always use HD Speed with a white polishing pad to deep clean the paint from any road grime or traffic film that wasn't removed during the washing or claying process and to bring out incredible gloss. I then always apply a paint sealant. I've never had an issue where the paint sealant only lasting a few weeks because it wasn't able to properly bond over HD Speed BUT someone else in this thread I believe said they DID have an issue when they applied WGDGPS over an AIO where the water behavior of WGDGPS was virtually non-existent after a month.
    Polish doesn't necessarily remove more clearcoat than an AIO. If you use HD Speed with the exact same pad, machine, speed, pressure, passes, etc as you do with HD Polish+ you'll be removing roughly the same amount of clear coat.
  3. Thanks SWETM thanked for this post
    Likes PaulMys, SWETM liked this post
  4. #53
    Senior Member PaulMys's Avatar
    Jan 2014
    L.I. NY
    2,326
    Quote Originally Posted by h8dirtycars View Post
    I use Speed to knock out my light blemishes, then either 845, or 476s. The Speed provides incredible gloss/slickness, and topped with either of the Collinite brothers, I can easily get 6 months (until I correct again) here in NY.
    When I use up most of the Collinite, I want to try HD Poxy as well.
  5. #54
    Feb 2017
    152
    Thanks, Paul.
  6. #55
    Jan 2014
    L.I. NY
    2,326
    Thanks, Paul.
  7. #56
    Sep 2017
    Sweden
    814
    Quote Originally Posted by mwoywod View Post
    Thanks for shareing your experience!
    I see the benefit of an AIO to clean the paint. And it's great if a sealant can get the 6 months longevity on top of Speed.
    That's a thing I have been wondering about how a water based polish cleans the paint. The old and some of the polish that is solvent based maybe cleaned it better. When doing a one step polish there could be a better result with a AIO which is often both chemical cleaners and fine abrasives in them.
  1. Topping a Coating with a Sealant
    Last Post: 10-02-2016, 11:02 PM
  2. Layering sealant and topping
    By Trevor02TA in forum Auto Detailing 101
    Last Post: 05-01-2013, 10:27 AM
  3. Glass sealant topping aquapel
    By jhnybgood47 in forum Auto Detailing 101
    Last Post: 04-25-2013, 06:13 AM
  4. Topping Sealant+Wax=Wasteful
    By Lasthope05 in forum Auto Detailing 101
    Last Post: 02-26-2012, 08:32 PM
  5. Topping Klasse Sealant on Red
    By DaC in forum Auto Detailing 101
    Last Post: 11-12-2011, 10:50 AM
