Re: Polishing pad care
Originally Posted by
carlg
So I did my convertible Mustang today (less polishing needed since there is no roof to do).
I used 3 pads.
When I was done, I washed them with soap and water and they seem to be fine and ready to go for next time!!
Don't use dish soap on your pads.
sudsmobile
I agree. Heck plain water works best..
I struggled with pad cleaning and staining for a while. Dedicated pad cleaner and a pad brush. I spray my pads, brush them, and rinse well. Rinse very well. A good pad cleaner will make all the difference. I'm using McKee's. I'm sure others are good as well.
RippyD
The McKees is excellent.
Sent from my SM-G950U using Autogeekonline mobile app
Clean them with APC or air pressure.
You can use APC. In my experience it doesn't work as well. My pads before I used pad cleaner are all stained, especially from darker polishes. With pad cleaner white pads stay perfectly white. With anything else I tried they get stained. I can post pictures of stained pads vs. clean ones. I haven't seen any polish/compound not come out completely with pad cleaner.
RippyD
409 has worked really well and doesn't seem to hurt the pads.
Poorboy's Tornado Pad Cleaner is really good. Much better than McKee's along with less toxic fumes.
The Guz
Seconded. Poorboy’s is really good and all I now use.
Al Schmidt
"Adventure, is a car called Riviera..."
