Results 1 to 3 of 3
    Super Member C5Longhorn's Avatar
    Jun 2015
    379
    How long before a coated panel can rest against a towel
    I have two panels off of my car and just applied a paint coating after polishing and prep. I'm figuring in a couple of days it would be safe to lay them down against a towel.
    Anyone ever have a similar situation?
    Sent from my Pixel 2 using Tapatalk
    Super Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,634
    Re: How long before a coated panel can rest against a towel
    Most coating instructions will say something to the effect of:
    keep away from water for 24 hours. If any water gets on the coating, remove it.
    I can only assume the method to remove that water would be with a towel. So, I'd say 24 hours minimum if they are in a heated space. But best to play it safe and double or triple that time.
    Some coatings allow for application of a topper within a few hours, that would require a towel as well, though you are adding something to the surface in that case.
    Static & Mobile detailing in Minneapolis & St. Paul. http://www.detailedcreationsmpls.com/
    Jun 2015
    379
    Thanks, I suspect you are correct that a few days should be sufficient.
  1. Replies: 2
    Last Post: 08-14-2020, 04:41 PM
  2. Replies: 9
    Last Post: 12-31-2016, 10:27 AM
  3. Replies: 19
    Last Post: 10-05-2016, 09:50 AM
  4. Best final panel wipe towel.
    By Kody in forum Ask your detailing questions!
    Last Post: 12-30-2015, 01:15 PM
  5. Repainted a panel, how long until wet sand and polish?
    By michael13 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 07-13-2011, 12:46 AM
