» Detailing Classes
Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
  1. #41
    Senior Member ClearVue18's Avatar
    Jan 2018
    Washington, DC
    163
    Re: Mobile Water Tank setup....need a little help
    If you get a gravity tank you won’t need a pump in the middle
  2. #42
    Senior Member sudsmobile's Avatar
    Jan 2018
    IE, SoCal
    465
    I mean is there any such thing as a "gravity tank?" Put the tank above your intended end point and gravity will take over. But it's not always that easy. What if you're down to your last 10 gallons of water and your last job of the day you're forced to park your rig facing downhill? Gravity is not always going to work. If you do this for a living, invest in a $60 pump. If you don't do this for a living, of course it's not necessary. It always amazes me what "professionals" will leave to chance or sheer dumb luck to save a few bucks.
  3. Likes 215Detailing liked this post
  4. #43
    Jan 2018
    IE, SoCal
    465
    Quote Originally Posted by 215Detailing View Post
    YouTube THIS is what you are looking for if I'm correct, just don't know fitting size/description etc. but this is about the best video currently available
    I'm not sure what question you're answering. He replaced his pump and now it works perfectly per his last post.
  5. #44
    Senior Member 215Detailing's Avatar
    May 2011
    1,052
    where did you find the hose (looks like 1/2 fittings on ends) the issue most times is fitting, when you get a shurflo pump with male fitting the fittings are usual 1/2 and need to converted or adapted to 3/4
  6. #45
    May 2011
    1,052
    @JustJesus where did you find the hose (looks like 1/2 fittings on ends) the issue most times is fitting, when you get a shurflo pump with male fitting the fittings are usual 1/2 and need to converted or adapted to 3/4
  7. #46
    Jan 2018
    Washington, DC
    163
    Not sure about all that I have 12 gravity tanks and I’ve never had a issue and never needed a pump in any of my fleets but to each there own all I say. We do 90-120 cars per day with our mobile fleet and never ran into that problem
  8. #47
    Senior Member WindyCity's Avatar
    Mar 2008
    461
    Quote Originally Posted by sudsmobile View Post
    It's your pump. It's bad. Get a Shurflo 12v on demand. $60 on Amazon. I run this off a 100 gallon tank to a 2.6gpm Subaru powered gas pressure washer. Never had a problem supplying water even running the pressure washer for 10 minutes straight. It only runs when there's demand, so only when you pull the trigger.
    SHURFLO 4008-101-A65 New 3.0 GPM RV Water Pump Revolution, 12V - - Amazon.com
    +1
    Same setup I had and it worked flawless
    David
  9. #48
    Mar 2008
    461
    , a good pump doesn't even need to be gravity fed.
    Yea my pump was completely above the tank
    Quote Originally Posted by 3Crowns View Post
    For those still following the thread, I wired up the new Shurflo pump and it works like a dream! Thanks for all the advice and recommendations guys!
    Glad that it worked out!
    David
  10. #49
    Senior Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    658
    Online retailer. The popular one. It's part of a silencing kit (just some short hoses, really) -SHURFLO (94-591-01) Pump Silencing Kit
    I'm not even sure why I got that.
    You can also use adapters (I had to get these anyway).
    I used Lasco (bought in the same place online)
    LASCO 15-1631 PVC Hose Adapter
    LASCO 15-1635 PVC Hose Adapter
    That's the thing with the Shurflo. 1/2 inch fittings. I looked and looked but couldn't find a "regular" garden hose (that was 1/2 inch fittings) to work. So I ended up buying those Lasco adapters to make it work with a 3/4 inch hose.
    One adapter, the female I think, goes from the tank to a white hose. The hose goes to the pump as shown in the pic. Out from the pump is the other white hose, which goes to the other adapter, and connects to a regular 3/4 inch hose.
    Hope that helps. - Oh, you could likely do without that "silencing kit"
  1. Mobile Van Water Tank...i forgot something
    By JonFD in forum Auto Detailing 101
    Last Post: 01-18-2018, 10:23 PM
  2. Water tank setup with just garden hose?
    By zpowell23 in forum Off-Topic
    Last Post: 09-15-2015, 01:01 PM
  3. RO/DI Water Tank Setup
    By fishnugget in forum Auto Detailing 101
    Last Post: 12-11-2012, 05:38 PM
  4. Mobile water tank
    By JohnnyCaretaker in forum Auto Detailing 101
    Last Post: 09-11-2010, 06:00 AM
  5. Mobile Water Tank/Pump Set-Up
    By AjNavo61490 in forum Show N' Shine
    Last Post: 05-17-2009, 02:42 AM
Members who have read this thread: 67
» August 2018
293031 1 2 3 4
